Cam lobes? Pics are up.
#1388507
02/16/13 04:15 PM
02/16/13 04:15 PM
Posts: 302 Middle of the US
Verga
Middle of the US
Do these lobes look OK? None of them are rounded, but they all have the same wear pattern. Cam has 700 miles and 40 or so passes.
Re: Cam lobes?
[Re: Verga]
#1388512
02/16/13 05:03 PM
02/16/13 05:03 PM
Verga
Middle of the US
The "shiney" area on the nose of the lobe is shinier and wider than Ive seen on my other used cams..fwiw.
"Im supercharged, might explode in your face"
Re: Cam lobes?
[Re: dennismopar73]
#1388514
02/16/13 07:04 PM
02/16/13 07:04 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
Get out your mic and measure the lobes top and sides see how much wear you have
I think unless a cam is extremely low duration that's not possible by directly micing the cam. With the lobe at 12 o'clock the 3 and 9 positions are well off base circle.
A person could measure the lift with the cam still in a block very accurately though.
Besides, virtually ANY measurable wear is a bad cam, as once it starts to go it goes very fast, and usually looks pretty ugly (scoring, galling) in the process.
Re: Cam lobes?
[Re: Pacnorthcuda]
#1388516
02/17/13 01:39 PM
02/17/13 01:39 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
when i measure cams, i use two blocks of wood with 'v' cuts in them and bolt on a degree wheel, using dial indicator to measure from lobe to lobe. magentic base on a steel bench, altho i have used just a plate to mount the base.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
