adjusting bumpsteer A body #1388386
02/16/13 02:19 PM
02/16/13 02:19 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
anyone know of a bump steer kit for A body?
don't want to spend 350 on hotchkis tie rods.
Re: adjusting bumpsteer A body [Re: mopar dave] #1388387
02/16/13 03:04 PM
02/16/13 03:04 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I don't think simply swapping in those tie rods will change your bump steer. Hotchkis makes an upper control arm that moves the piviot point upwards on the rear of the control arm, but it's expensive.
It's supposed to better match the sweep radius of the lower control arm's travel from full compression to full rebound, to the sweep radius of the outer tie rod end's sweep radius during full compression to full rebound. I'm no expert, but my stock suspension doesn't bump steer that bad at all. I did have to massage a few things to get them lined up to where they like to be.
Try posting in the Handling section. There's a lot of guys that know tons about this topic like AutoxCuda and others.
Direct Connection published a book on Chassis's that addresses this issue in detail.
Re: adjusting bumpsteer A body [Re: mopar dave] #1388388
02/16/13 03:13 PM
02/16/13 03:13 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
You will need some sort of Heim ended tie rods if you want to be able to make an adjustment/correction to get the bump steer you are looking for.
You will also need to buy or make a bumpsteer gauge and buy adjustment shims.
Re: adjusting bumpsteer A body [Re: autoxcuda] #1388389
02/16/13 03:48 PM
02/16/13 03:48 PM
Mt Morris Michigan
Mt Morris Michigan
I have tubular upper control arms. I read the chassis book and what i under stand is the outer tr end needs to be lowered. John calvert told me to use spacers, but somebody must make a kit. Last time i measured mine i had something like 1" of toe in at 3 or 4" rebound. Need to correct this.
Re: adjusting bumpsteer A body [Re: mopar dave] #1388390
02/16/13 03:56 PM
02/16/13 03:56 PM
So Cal
So Cal
To set or change the bumpsteer you have to shim or somehow move the tie rods. Unless the new parts just measured out a better bumpsteer than before. Which is cool.
If anyone is more interested in the details of bump steering a car read here:
Making Bump Steer Corrections: http://www.longacreracing.com/articles/art.asp?ARTID=13#Q3
BTW these Longacre tech articles are pretty darn good :
http://www.longacreracing.com/articles/index.asp
Re: adjusting bumpsteer A body [Re: autoxcuda] #1388391
02/16/13 04:01 PM
02/16/13 04:01 PM
Mt Morris Michigan
Mt Morris Michigan
If you look at the hotchkis t rods they have spacers on the outer ends. I dont need the whole t rod just the outer end with the spacer. Ill read the articles. Thanks
Re: adjusting bumpsteer A body [Re: mopar dave] #1388392
02/16/13 04:06 PM
02/16/13 04:06 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
Dave look @ what summit has available ,maybe some will work .they have ends only with spacers....went through this when i installed my cap k member kit pat
Re: adjusting bumpsteer A body [Re: mopar dave] #1388393
02/16/13 04:10 PM
02/16/13 04:10 PM
So Cal
So Cal
You need to change at least the outer tie rod to a spherical rod end and run a taper to straight bolt conversion in the end of the steering arm; called a "tie rod adapter stud". Circle track supply places have those.
http://www.speedwaymotors.com/Adjustable...CFcdxQgodpWAAwg
Re: adjusting bumpsteer A body [Re: pattyboy 572] #1388394
02/16/13 04:14 PM
02/16/13 04:14 PM
Mt Morris Michigan
Mt Morris Michigan
ill check summit.
Re: adjusting bumpsteer A body [Re: autoxcuda] #1388395
02/16/13 04:16 PM
02/16/13 04:16 PM
Mt Morris Michigan
Mt Morris Michigan
looks like what I need. what else will I need to go with it? thanks
Re: adjusting bumpsteer A body [Re: autoxcuda] #1388396
02/16/13 04:17 PM
02/16/13 04:17 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Are the tie rods always to low?
The parts are available at Speedway to make what ever you need to raise them. To low,in,or out and the arms will need to be bent.
Doug
Re: adjusting bumpsteer A body [Re: mopar dave] #1388397
02/16/13 04:17 PM
02/16/13 04:17 PM
So Cal
So Cal
You must convert that end you need the adjustment to a tie rod adapter with spherical rod end at the least. (I would suggest just converting the whole tie rod arm assembly to sphericals inner and outer. You may need to adjust the inner tie rod too.)
Then make the adjustment and fine adjustment you get a bump steer shim kit:
http://www.quickcar.net/index.php?crn=233&rn=776&action=show_detail
And of course you will need a bump steer gauge:
http://www.google.com/search?sourceid=na...Aw&bav=on.2,or.r_gc.r_pw.r_qf.&bvm=bv.42661473,d.cGE&fp=f8b817aa2f760986&biw=1280&bih=530
Re: adjusting bumpsteer A body [Re: autoxcuda] #1388398
02/16/13 04:25 PM
02/16/13 04:25 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
look at places that sell circle track stuff you can get the stuff to do the tie rods for around 100 bucks.
Re: adjusting bumpsteer A body [Re: dvw] #1388399
02/16/13 04:28 PM
02/16/13 04:28 PM
So Cal
So Cal
Doug
I agree. I don't think there is a tie rod adapter to up the stud coming out on the small part of the taper???
When I checked mine, I needed to remove spacers to make this 100% theorically perfect. But mine was allready at the lowest setting.
Luckily, my numbers were very good. The circle track and road course chassis builder told me just to leave it.
Edit: Just an FYI, 0.082" is only a little over 1/16" toe out at 3" compression. And 0.114" is only a little under 1/8" toe in at 3" rebound/extension.
I run probably close to 4 TIMES the spring rate a drag car does with my 1.14" T-bar. So I might only see those 3" numbers in a few corners on a road course.
Re: adjusting bumpsteer A body [Re: mopar dave] #1388400
02/16/13 05:11 PM
02/16/13 05:11 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://www.dillingerchassis.com/product/tie-rod-to-heim-joint-conversion/
chromemoly or aluminium sleeves
Tony
70 AARCuda Vitamin C
Re: adjusting bumpsteer A body [Re: 70AARcuda] #1388401
02/16/13 07:06 PM
02/16/13 07:06 PM
Mt Morris Michigan
Mt Morris Michigan
Well I added the tubular uppers and had caster set to 4* which I think knocked by bump steer way off. I thought after reading the chassis book I needed to lower the outer ends. Just want to get it closer than 1"@3" rebound.maybe I'm wrong and need to raise them.
Re: adjusting bumpsteer A body [Re: mopar dave] #1388402
02/16/13 07:18 PM
02/16/13 07:18 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
here is the end result of fixing my bumpsteer. looks slightly different from this, ended up using a shorter bolt and after tweeking the spacer was slightly shorter, plus I used a large washer under the heim joint to contain everything in case of joint failure.
Re: adjusting bumpsteer A body [Re: mopar dave] #1388403
02/16/13 08:38 PM
02/16/13 08:38 PM
So Cal
So Cal
Well I added the tubular uppers and had caster set to 4* which I think knocked by bump steer way off. ...
This are my alignment specs with the above bumpsteer measurement table:
toe: 1/16" toe in
camber: negative 1.5 degrees (top of tire in)
caster: postive 5.9 degrees
Re: adjusting bumpsteer A body [Re: mopar dave] #1388404
02/16/13 08:55 PM
02/16/13 08:55 PM
So Cal
So Cal
.... I thought after reading the chassis book I needed to lower the outer ends. Just want to get it closer than 1"@3" rebound.maybe I'm wrong and need to raise them.
I was pretty close on my numbers so I did not make an adjustment.
But I did notice something going back on that Longacre bump steer guide:
C. Making Bump Steer Corrections
Now that you have measured your bump steer you will need to adjust, shim or relocate the suspension components to get the exact reading that you desire. Below are some tips that will quickly guide you through the corrective process for cars with front steer style suspension.
I'm pretty sure that makes the Bump Steer Chart useless for rear steer cars. Almost positive.
I'm pretty sure for a rear steer cars you would swap all the "toe out" symptoms with "toe in". I'd have to think about it a bunch. But I would use the DC Chassis chart/guide.
Get the tie rod linkage you can adjust, get a bump steer gauge, get adjustment shims, and then go through the process. Add and take away a bunch of shims and record what happens. You will for sure learn what works for your car and have a better understanding on what is going on. That understanding WILL make you faster now, stay faster, and make you faster in the future.
Re: adjusting bumpsteer A body [Re: autoxcuda] #1388405
02/16/13 09:27 PM
02/16/13 09:27 PM
Mt Morris Michigan
Mt Morris Michigan
My measurements are
1/16 toe in
0 camber
4 caster
