727's and 1000 ft / lb plus? #1388296
02/16/13 06:05 AM
02/16/13 06:05 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
As the thread implies, what do I need for inside a 727 for survival and reliability at that level?
Any experiences?
Re: 727's and 1000 ft / lb plus? [Re: Tig] #1388297
02/16/13 10:14 AM
02/16/13 10:14 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
A super sprag like a COAN.
Re: 727's and 1000 ft / lb plus? [Re: Tig] #1388298
02/16/13 11:25 AM
02/16/13 11:25 AM
Tucson AZ.
RADAMX Offline
RADAMX  Offline
Tucson AZ.
Only thing I have ever broke was I took the splines out of an aluminum planet gear assembly. replaced with steel spline and never had a problem .
Of course you need a bilit drum ,A low band apply valve body. As said a sprag. I also run the roller rear drum but I don't think it is a must.
3345 lbs and just over 1000 ft tq
Oh ya a good convertor .
Good luck
Re: 727's and 1000 ft / lb plus? [Re: Tig] #1388299
02/16/13 11:34 AM
02/16/13 11:34 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
a trans blanket
home of the
Sox and Martin Hemi Duster
Re: 727's and 1000 ft / lb plus? [Re: Tig] #1388300
02/16/13 12:38 PM
02/16/13 12:38 PM
gregsdart Offline
gregsdart  Offline
Monty, a nitrous racer that used to post on hear said he started breaking output shafts at about that level. It is possible that the torque he had was higher than that due to the nitrous.
Re: 727's and 1000 ft / lb plus? [Re: HEMIFRED] #1388301
02/16/13 07:51 PM
02/16/13 07:51 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
a trans blanket
Sharp as ever Fred
Tig,
There a few folks I have read or spoken too, that have had success with High Hp/Torque combos running 727's. Even with the best of parts, they seem to all need regular maintenance or consistently need to be checked over.
Re: 727's and 1000 ft / lb plus? [Re: mopar_mark] #1388302
02/17/13 12:55 AM
02/17/13 12:55 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
And I'm still pushing buttons
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 727's and 1000 ft / lb plus? [Re: hemi-itis] #1388303
02/17/13 01:44 AM
02/17/13 01:44 AM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
I hate to say it but I miss those days , I never had an issue with missing gears , CO2 bottle going empty , I actually liked to use the push buttons . But I wanted to update to the newer stuff .... you know the story . Gary
Re: 727's and 1000 ft / lb plus? [Re: Gabby63] #1388304
02/17/13 08:39 AM
02/17/13 08:39 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Hi, thanks for the replies
I have some good stuff in it at the moment. Billet drum, 5 pinion steel planetary (front), bolt in sprag (standard # of elements though) LBA MVB etc etc.
I was going to add H/D or billet I/p and O/p shafts and hope for the best.
I don't mind the maintenance, how often were they pulling it apart Mark? That having been said, I just rebuilt mine after 4 seasons and it didn't really need it. The current motor is not into 4 figures though.
Do I need to do more?
I'd rather not go to a th400
TIA.
Tig
