Re: Hemi rocker arms
[Re: hudsonhornet7x]
#1387587
02/14/13 08:58 PM
02/14/13 08:58 PM
Posts: 1,739 Grand Forks, ND
Hemi_Ram
Grand Forks, ND
I too, had problems with oiling on the Indy exhaust rockers; cured that with oil through the pushrods.
[Re: Dan Brewer]
#1387588
02/14/13 08:59 PM
02/14/13 08:59 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
The Landy and Mopar performance roller tip rockers do not oil the tips very well, especially when the oil is cold. to compensate, I have opened up the groove in the number four cam journal to provide more oil to the valvetrain. also I do not use straight weight oil. I use 1030 or 1040, because it gets oil to the roller tips quicker. If you are using a flat tappet cam, stock Hemi rockers will be fine.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Ram]
#1387594
02/15/13 11:42 AM
02/15/13 11:42 AM
Posts: 75,010 U.S.S.A.
JohnRR
U.S.S.A.
I too, had problems with oiling on the Indy exhaust rockers; cured that with oil through the pushrods. Anyway check this guys feedback; looks like he has a lot of satisfied customers.
http://feedback.ebay.com/ws/eBayISAPI.dl...eedbackAsSeller
I wouldn't rely on this guys ebay feedback to gauge the quality of those cheap chinese junk rockers . Most ebay users fear retalitory negative feedback so they will not give it , plus you only have 90 days to leave feedback , I doubt 75% of those rockers sold were installed with the feedback period .
I haven't seen anything good posted about them that I can remember.
[Re: JohnRR]
#1387595
02/15/13 11:56 AM
02/15/13 11:56 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Everything I've heard about those rockers hasn't been good. I use the DLI roller rockers w/ MP shafts and stands on my hemi w/ a solid roller. Zero issues since 2006.
[Re: Hooligan]
#1387600
02/15/13 05:26 PM
02/15/13 05:26 PM
Posts: 413 Norway (old world)
Oyvind Mopar
Norway (old world)
I also bought a set. Same issues. I did not dare to buy with roller tips, and went stock type. They were too short and ground with wrong starting point for the radius. If used as is, it would have worn out the guides/valvestems in a short time. I checked with X-referance to stock old Mopar rockers and found out that the brackets were not the problem, but the rockers needed welding/extending and regriding the tips. Also lacked all the hold down bolts when I got the set. Too late for me in Norway to challenge the feedback when I finally got them. I have used stock rockers sold on the bag with better results, although some have had worn tips (easy fix). My old rockers ran 9000 rpms with Crane R290 in the old days, no issues with them. But I needed to check/grind the radius for correct fitness to the valvestem top with that camshaft back then.
[Re: Oyvind Mopar]
#1387601
02/15/13 07:19 PM
02/15/13 07:19 PM
Posts: 2,111 Byron, NY
W.I.N. Racing
Byron, NY
Stage V's best rocker for the $$$$ spent.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
#1387604
02/17/13 01:00 PM
02/17/13 01:00 PM
Posts: 12,080 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have followed threads on Hemi rockers on here for some time now. There are a lot of guys that have said here that they have run the stock rockers for years with good success. And certainly, there are good reviews for T&D, DLI, Stage V and the like.
But there seems to be a lot of bad experiences for other brands of Hemi rockers. It almost seems that it is either best to run stockers, within reason, or go to the top ranks of rockers.
How do the newer MP stock replacements stack up? Are they up to the standards that their OE counterparts?
Master, again and still
[Re: DaveRS23]
#1387605
02/17/13 02:24 PM
02/17/13 02:24 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
stock narrow or wide will do the trick with a cam lift under .750 at one time 9500 rpm was the norm for them
home of the Sox and Martin Hemi Duster
[Re: 572charger]
#1387606
02/17/13 04:45 PM
02/17/13 04:45 PM
Posts: 621 Iowa
coronetville
Iowa
what about norris rockers?
[Re: nz383man]
#1387611
02/18/13 07:57 AM
02/18/13 07:57 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
So on a build where the stock rockers would be OK, how does a guy check the ratio ?
You have to mock it up with light checker springs. Install the cam and one intake and exhaust lifter, checker springs on said cylinder. Set the it at zero lash and using a dial indicator record maximum lifts go back to your cam card or using a dial indicator measure total lobe lift at the cam. Divide the maximum valve lift by the maximum lobe lift the product is your rocker ratio. You'll have to do this for each rocker arm. Dave
[Re: nz383man]
#1387613
02/19/13 01:25 AM
02/19/13 01:25 AM
Posts: 43,180 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#1387614
02/19/13 08:08 AM
02/19/13 08:08 AM
quickd100
nielsville, minn.
Cab you are so right. It can turn a normal guy into a tear streaked raving lunatic. Other than living with it the only options using stock rockers are to send them out for correction,(they can make them better but not perfect) or find a way to dig through and check dozens of individual rockers. Mine were redone and I bought another complete set from a member here. I checked them all and used the best of them to make a set. Here are the ratios I ended up with; on the intake 1.69, 1.63, 1.66, 1.66,1.67,1.66,1.65,1.63 the exhausts, 1.53,1.52,1.51,1.49,1.51,1.52,1.53,1.50 The net differences in lift on mine are only .026 on the intake and .017 on the exhaust, I can live with that. It still bothers me but it's much better than most.Dave
[Re: scatpacktom]
#1387616
02/19/13 03:36 PM
02/19/13 03:36 PM
quickd100
nielsville, minn.
Where are we sending them these days? I know RAS had some problems lately. Tim Banning?
Tim did mine but that was 4-5 years ago now. Dave
