Re: Hemi rocker arms [Re: hudsonhornet7x] #1387604
02/17/13 01:00 PM
02/17/13 01:00 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have followed threads on Hemi rockers on here for some time now. There are a lot of guys that have said here that they have run the stock rockers for years with good success. And certainly, there are good reviews for T&D, DLI, Stage V and the like.
But there seems to be a lot of bad experiences for other brands of Hemi rockers. It almost seems that it is either best to run stockers, within reason, or go to the top ranks of rockers.
How do the newer MP stock replacements stack up? Are they up to the standards that their OE counterparts?
Master, again and still
Re: Hemi rocker arms [Re: DaveRS23] #1387605
02/17/13 02:24 PM
02/17/13 02:24 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
stock narrow or wide will do the trick with a cam lift under .750
at one time 9500 rpm was the norm for them
home of the
Sox and Martin Hemi Duster
Re: Hemi rocker arms [Re: 572charger] #1387606
02/17/13 04:45 PM
02/17/13 04:45 PM
Iowa
coronetville Offline
Iowa
what about norris rockers?
Re: Hemi rocker arms [Re: coronetville] #1387607
02/17/13 05:59 PM
02/17/13 05:59 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
my experience they were the worse I ever had. When checked the intake ratio was only 1.42
home of the
Re: Hemi rocker arms [Re: HEMIFRED] #1387608
02/17/13 06:31 PM
02/17/13 06:31 PM
Iowa
Iowa
Sometimes this forum can be a really big help, and money saver, thanks,was on the verge of buying some
Re: Hemi rocker arms [Re: hudsonhornet7x] #1387609
02/17/13 07:09 PM
02/17/13 07:09 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
The stock rockers work great but when you start checking ratios on each rocker you quickly find that they are all over the place. I sent mine to Tim Banning to be corrected, he called me and asked where I'd gotten them as they were really bad. He was nice enough to dig up a set of wide pad old pro stock rockers and rebuild them for me. Dave
Re: Hemi rocker arms [Re: quickd100] #1387610
02/18/13 07:33 AM
02/18/13 07:33 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
So on a build where the stock rockers would be OK, how does a guy check the ratio ?
Re: Hemi rocker arms [Re: nz383man] #1387611
02/18/13 07:57 AM
02/18/13 07:57 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
You have to mock it up with light checker springs. Install the cam and one intake and exhaust lifter, checker springs on said cylinder. Set the it at zero lash and using a dial indicator record maximum lifts go back to your cam card or using a dial indicator measure total lobe lift at the cam. Divide the maximum valve lift by the maximum lobe lift the product is your rocker ratio. You'll have to do this for each rocker arm. Dave
Re: Hemi rocker arms [Re: quickd100] #1387612
02/18/13 01:47 PM
02/18/13 01:47 PM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
Thanks Dave.
Re: Hemi rocker arms [Re: nz383man] #1387613
02/19/13 01:25 AM
02/19/13 01:25 AM
I use to check one set of rocker arms at a time on one bank, make sure the lift at the lobes are all the same and like already said use checking springs I was terribly shocked on how bad the stock rockers vary on the ratio I saw right at .130 differences at the retainers in lift between rocker arms on the same cam
Re: Hemi rocker arms [Re: Cab_Burge] #1387614
02/19/13 08:08 AM
02/19/13 08:08 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Cab you are so right. It can turn a normal guy into a tear streaked raving lunatic. Other than living with it the only options using stock rockers are to send them out for correction,(they can make them better but not perfect) or find a way to dig through and check dozens of individual rockers.
Mine were redone and I bought another complete set from a member here. I checked them all and used the best of them to make a set. Here are the ratios I ended up with;
on the intake 1.69, 1.63, 1.66, 1.66,1.67,1.66,1.65,1.63
the exhausts, 1.53,1.52,1.51,1.49,1.51,1.52,1.53,1.50
The net differences in lift on mine are only .026 on the intake and .017 on the exhaust, I can live with that. It still bothers me but it's much better than most.Dave
Re: Hemi rocker arms [Re: quickd100] #1387615
02/19/13 09:38 AM
02/19/13 09:38 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Where are we sending them these days? I know RAS had some problems lately. Tim Banning?
Re: Hemi rocker arms [Re: scatpacktom] #1387616
02/19/13 03:36 PM
02/19/13 03:36 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Tim did mine but that was 4-5 years ago now. Dave
Re: Hemi rocker arms [Re: Hooligan] #1387617
02/19/13 04:05 PM
02/19/13 04:05 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
here. Jesel 8000-8200 rpm and no issues
