Hemi rocker arms #1387584
02/14/13 08:24 PM
02/14/13 08:24 PM
USA
hudsonhornet7x Offline OP
USA
I have a question about hemi arms. I know in the big block world thee are a few different rocker arms that you want to stay away from. Is this also true in the hemi world? In other words are their hemi rockers that are crap, and if so what should I look for?
This would be for a street car with 500+ cubes and a 4 speed.
Thanks!
Re: Hemi rocker arms [Re: hudsonhornet7x] #1387585
02/14/13 08:35 PM
02/14/13 08:35 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Had oiling problems with indy exhaust rockets. Went back to stock wide pads. 572" 7500 rpm no issues.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Hemi rocker arms [Re: Dan Brewer] #1387586
02/14/13 08:48 PM
02/14/13 08:48 PM
USA
USA
Re: Hemi rocker arms [Re: hudsonhornet7x] #1387587
02/14/13 08:58 PM
02/14/13 08:58 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
I too, had problems with oiling on the Indy exhaust rockers; cured that with oil through the pushrods.
Re: Hemi rocker arms [Re: Dan Brewer] #1387588
02/14/13 08:59 PM
02/14/13 08:59 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
The Landy and Mopar performance roller tip rockers do not oil the tips very well, especially when the oil is cold. to compensate, I have opened up the groove in the number four cam journal to provide more oil to the valvetrain. also I do not use straight weight oil. I use 1030 or 1040, because it gets oil to the roller tips quicker.
If you are using a flat tappet cam, stock Hemi rockers will be fine.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi rocker arms [Re: hudsonhornet7x] #1387589
02/14/13 09:28 PM
02/14/13 09:28 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Thanks!
I paid top dollar for a set of mopar wide pads, the ratio's were all over the place so I sent the off to RAS, they made the ratio's even but then I was about 1.36 for a ratio insead of the 1.52, so it was another 1800 for a set of stageV rollers. I also upgraded to .250 Dechellies shafts
Go big or go home is where I was left at with these...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Hemi rocker arms [Re: astjp2] #1387590
02/14/13 10:04 PM
02/14/13 10:04 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I use a set of stock wide pad rockers too, I had Tim Banning go through them. 1.69/1.52. I use them on a solid roller, no oiling problems.Dave
Re: Hemi rocker arms [Re: hudsonhornet7x] #1387591
02/14/13 11:01 PM
02/14/13 11:01 PM
Stage V rockers for the street would be my choice
Re: Hemi rocker arms [Re: Cab_Burge] #1387592
02/14/13 11:09 PM
02/14/13 11:09 PM
hustlin hoosier Offline
WE have stageV in our big motor, but I have run Indy in several engines with no problem.
Re: Hemi rocker arms [Re: Hemi_Ram] #1387593
02/14/13 11:14 PM
02/14/13 11:14 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Here is the cam I used to run...Full roller deal that I ran on the street and track! Now remember those numbers are with stock rockers, I run the higher lift Indy rockers....Ask me how much three sets of push rods, two sets of lash caps, and one set of valve guides cost $$$$$
Here is my new cam! This one is a full mechanical I run on street/strip.
Re: Hemi rocker arms [Re: Hemi_Ram] #1387594
02/15/13 11:42 AM
02/15/13 11:42 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I too, had problems with oiling on the Indy exhaust rockers; cured that with oil through the pushrods. Anyway check this guys feedback; looks like he has a lot of satisfied customers.
http://feedback.ebay.com/ws/eBayISAPI.dl...eedbackAsSeller
I wouldn't rely on this guys ebay feedback to gauge the quality of those cheap chinese junk rockers . Most ebay users fear retalitory negative feedback so they will not give it , plus you only have 90 days to leave feedback , I doubt 75% of those rockers sold were installed with the feedback period .
I haven't seen anything good posted about them that I can remember.
Re: Hemi rocker arms [Re: JohnRR] #1387595
02/15/13 11:56 AM
02/15/13 11:56 AM
an8sec70cuda Offline
Everything I've heard about those rockers hasn't been good.
I use the DLI roller rockers w/ MP shafts and stands on my hemi w/ a solid roller. Zero issues since 2006.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi rocker arms [Re: JohnRR] #1387596
02/15/13 12:02 PM
02/15/13 12:02 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
A customer brought in a set and the stands wouldn't register on the head dowels and line up with the head bolt holes and the shafts wouldn't pass through all the stand holes.Ratios were all over the place and one pin fell out of the roller on one arm.We went over them and restaked all the roller pins.
Re: Hemi rocker arms [Re: B G Racing] #1387597
02/15/13 01:01 PM
02/15/13 01:01 PM
USA
USA
Thank you guys for the replies. The price seemed too good to be true on those ebay units, and being new to the hemi engine I did not know if there were parts to stay away from. That is what this thread is about!
Re: Hemi rocker arms [Re: hudsonhornet7x] #1387598
02/15/13 02:05 PM
02/15/13 02:05 PM
USA
Hooligan Offline
Hooligan  Offline
USA
OMG! Those rockers on ebay from 1hemiman in Canada are total garbage! DO NOT WASTE YOUR MONEY ON THOSE! He sent me three different sets and I had to send them all back, and I had to pay the shipping cost! Some of the roller pins could be pushed out by hand! From there I bought the Indy roller rockers and they were junk too! The Indy's have terrible geometry...terrible machine work...and terrible oiling! They didn't even clean off the burrs left by the machining process!
I lost a lot of money trying to save money on buying crap! I finally bought Stage V rollers from Tim Banning at For Hemis Only, and they are they best I ever seen, and the price is not bad. I spent the extra money on the Manton T/F rocker shafts, which are over-kill on my street engine, but the finish is phenomenal! The Stage V geometry is absolutely perfect which saves money down the road on guides and such. The oiling design is great! The machine work is gorgeous! The finish on the bushings is so beautiful that I could see the difference with by bare eyes!
Forget Indy & ebay 1hemiman & Mopar performance! Call Tim now, because he only get a limited number of per year. Also beware if you pay with a credit card. My Mastercard charged me a $56.00 fee for some sort of usage Canadian bullsh#t!
Trust me! Learn from my mistakes!!!
Re: Hemi rocker arms [Re: Hooligan] #1387599
02/15/13 03:10 PM
02/15/13 03:10 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I ordered mine directly from StageV, and the shafts Directly from Dichellies. Their prices are comparable with their vendors. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Hemi rocker arms [Re: Hooligan] #1387600
02/15/13 05:26 PM
02/15/13 05:26 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
I also bought a set. Same issues. I did not dare to buy with roller tips, and went stock type. They were too short and ground with wrong starting point for the radius. If used as is, it would have worn out the guides/valvestems in a short time. I checked with X-referance to stock old Mopar rockers and found out that the brackets were not the problem, but the rockers needed welding/extending and regriding the tips. Also lacked all the hold down bolts when I got the set. Too late for me in Norway to challenge the feedback when I finally got them.
I have used stock rockers sold on the bag with better results, although some have had worn tips (easy fix).
My old rockers ran 9000 rpms with Crane R290 in the old days, no issues with them. But I needed to check/grind the radius for correct fitness to the valvestem top with that camshaft back then.
Re: Hemi rocker arms [Re: Oyvind Mopar] #1387601
02/15/13 07:19 PM
02/15/13 07:19 PM
Byron, NY
W.I.N. Racing Online content
W.I.N. Racing  Online Content
Byron, NY
Stage V's best rocker for the $$$$ spent.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Hemi rocker arms [Re: W.I.N. Racing] #1387602
02/16/13 12:13 PM
02/16/13 12:13 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Lots of $$$ NO
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Hemi rocker arms [Re: chryco] #1387603
02/17/13 09:51 AM
02/17/13 09:51 AM
pa
572charger Offline
572charger  Offline
pa
ive got the t-d ray bartons on my 606 hemi just took them off yesterday to freshen the motor after 8000+ miles and 150 passes with a 720 lift 282 duration cam pushrods and rockers have no wear what so ever !!! best money ive spent since lasik surgery !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
