Do you grease your balls? #1387561
02/14/13 06:38 PM
02/14/13 06:38 PM
Kalispell Mt.
HotRodDave Online content OP
HotRodDave  Online Content OP
Kalispell Mt.
I don't know if it makes any differance when pulling a trailer if you grease your balls or leave them dry. What do you guys do?
Re: Do you grease your balls? [Re: HotRodDave] #1387562
02/14/13 06:55 PM
02/14/13 06:55 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
YES I GREASE MY BALLS! You really should put some type of lube on them . LOL if you don't it just grinds away at them ! Look at a fifth wheel hitch plate. I see new fifth wheel hitches that have a Teflon coating on them .
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Do you grease your balls? [Re: HotRodDave] #1387563
02/14/13 07:28 PM
02/14/13 07:28 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Re: Do you grease your balls? [Re: HotRodDave] #1387564
02/14/13 08:03 PM
02/14/13 08:03 PM
Tidewater, VA
TMCCuda Offline
TMCCuda  Offline
Tidewater, VA
I don't see any reason to. I help deliver hay and straw. We put alot of miles on each year. No grease and the same hitch ball for years. None of the pins on any of the tractor equipment whether its draw bar or 3 point hitch get greased. Most of that equipment sees a helluva lot more pressure than a car trailer. We save the grease for the bearings and moving parts.
1970 Plymouth Barracuda 1994 Ram 1500 4x4 5.2L 2004 Ram 1500 4x4 5.7L Quad Cab
Re: Do you grease your balls? [Re: TMCCuda] #1387565
02/14/13 08:14 PM
02/14/13 08:14 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Grease collects dirt and other grit which really grinds on the ball and socket. Leave it dry.
Re: Do you grease your balls? [Re: stumpy] #1387566
02/14/13 08:18 PM
02/14/13 08:18 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
Re: Do you grease your balls? [Re: HotRodDave] #1387567
02/14/13 08:35 PM
02/14/13 08:35 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
But what if it leaving it dry pulls the chrome off your balls? Then you can't polish them.
Re: Do you grease your balls? [Re: HotRodDave] #1387568
02/14/13 09:18 PM
02/14/13 09:18 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Always use grease, clean it off once in while and re grease.
I remember reading somewhere that if you don't grease it the two can gall together enough to cause control problems. Mine squeaks when it needs grease and I clean if off and re grease, both the ball and the hitch.
Can't imagine trailing across America at 75 mph with A DRY HITCH, THAT'S ASKING FOR TROUBLE,IMO. I have made a bunch of trips out west and go 5000+ miles before unhitching my trailer, it can't go that long metal to metal without wearing out and possibly coming off the ball!!
I've done a bunch of trailing, your nut's if your on our highways with a dry hitch and a danger to the rest of us.
Re: Do you grease your balls? [Re: Challenger 1] #1387569
02/14/13 10:23 PM
02/14/13 10:23 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
ive run dry before and seen where it had started to grind against the ball. understand grease collects dirt but clean and regrease. you repack your wheel bearings dont you? how hard is it to smear grease on a trailer ball? grease and be safe !! tube of grease $5
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Do you grease your balls? [Re: hulmule] #1387570
02/14/13 10:54 PM
02/14/13 10:54 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Well, darned, I put over 150,000 miles on my truck and trailer when I was hauling cars and another 30,000 all those years racing, I never put a drop of grease on the ball. Same ball (I'm a cheap bum) and the trailer coupler was the same one as well. I did have to change the coupler one time after I let someone borrow my trailer and he bent the tongue and coupler. Didn't notice any wear on the coupler, and the chrome was still good on the ball. It was probably the quality of the chrome on the ball that "saved" me.
I just hate to think of all those "unsafe" miles I logged on my truck and trailer without greasing the ball.
However, given the current quality of available parts around these days, I would probably grease the ball if I was going to do much towing now. Gene
Re: Do you grease your balls? [Re: poorboy] #1387571
02/14/13 11:08 PM
02/14/13 11:08 PM
E. Okla line
m88mark Offline
m88mark  Offline
E. Okla line
I grease mine. That way when people bark their shins on my hitch the grease helps stop the bleeding. Don't know why they can't see a hitch sticking out!
Re: Do you grease your balls? [Re: m88mark] #1387572
02/14/13 11:32 PM
02/14/13 11:32 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
We have some goose neck trailers at work and we started using them dry by mistake(just didn't think about it) when they were new. It didn't take long for them to have metal shavings in the bed. It was amazing how much more quite they were once we greased them. We have a grease gun in the warehouse and just give them a squirt when we think about it now, no problems.
68 Barracuda Formula S 340
Re: Do you grease your balls? [Re: Bad340fish] #1387573
02/14/13 11:57 PM
02/14/13 11:57 PM
Kirkland, Washington
Pacnorthcuda Offline
I stopped when I was about 16, since then I've subbed the job out.
Re: Do you grease your balls? [Re: HotRodDave] #1387574
02/15/13 12:05 PM
02/15/13 12:05 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I hire a staff of properly trained professionals to care for my balls...
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Do you grease your balls? [Re: HotRodDave] #1387575
02/15/13 01:24 PM
02/15/13 01:24 PM
USA
Hooligan Offline
Hooligan  Offline
USA
Ohhh...at first I thought you were referring to my balls, because I only have one trailer ball! Anyway, of my three balls, I only deliberately put grease on one of them...the other two tend to get all greasy when, nevermind!
Re: Do you grease your balls? [Re: HotRodDave] #1387576
02/15/13 07:14 PM
02/15/13 07:14 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
for the first time in internet history, this thread is perfectly fine without pictures.
Re: Do you grease your balls? [Re: Golden-Arm] #1387577
02/15/13 09:16 PM
02/15/13 09:16 PM
USA
Hooligan Offline
Hooligan  Offline
USA
Amen to that, but you just gave everyone that scary idea!
YIKES!!! Time to set the nasty photo censorship dial to maximum!
Re: Do you grease your balls? [Re: Hooligan] #1387578
02/15/13 09:55 PM
02/15/13 09:55 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
...Does K-Y count...
Re: Do you grease your balls? [Re: emarine01] #1387579
02/15/13 10:56 PM
02/15/13 10:56 PM
Cincinnati, Ohio
Cincinnati, Ohio
Yes that'll work, sure better than nothing.
Re: Do you grease your balls? [Re: Challenger 1] #1387580
02/16/13 12:09 PM
02/16/13 12:09 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
A little Polygrip can be used to tighten up loose ball couplers.
