Do you grease your balls?
#1387561
02/14/13 06:38 PM
02/14/13 06:38 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I don't know if it makes any differance when pulling a trailer if you grease your balls or leave them dry. What do you guys do?
Re: Do you grease your balls?
[Re: HotRodDave]
#1387562
02/14/13 06:55 PM
02/14/13 06:55 PM
Posts: 1,404 northeast ohio
hulmule
northeast ohio
YES I GREASE MY BALLS! You really should put some type of lube on them . LOL if you don't it just grinds away at them ! Look at a fifth wheel hitch plate. I see new fifth wheel hitches that have a Teflon coating on them .
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: HotRodDave]
#1387564
02/14/13 08:03 PM
02/14/13 08:03 PM
Posts: 178 Tidewater, VA
TMCCuda
Tidewater, VA
I don't see any reason to. I help deliver hay and straw. We put alot of miles on each year. No grease and the same hitch ball for years. None of the pins on any of the tractor equipment whether its draw bar or 3 point hitch get greased. Most of that equipment sees a helluva lot more pressure than a car trailer. We save the grease for the bearings and moving parts.
1970 Plymouth Barracuda
1994 Ram 1500 4x4 5.2L
2004 Ram 1500 4x4 5.7L Quad Cab
[Re: stumpy]
#1387566
02/14/13 08:18 PM
02/14/13 08:18 PM
Posts: 589 Fortworth TX
mod5v
Fortworth TX
Grease collects dirt and other grit which really grinds on the ball and socket. Leave it dry.
[Re: HotRodDave]
#1387568
02/14/13 09:18 PM
02/14/13 09:18 PM
Challenger 1
Cincinnati, Ohio
Always use grease, clean it off once in while and re grease. I remember reading somewhere that if you don't grease it the two can gall together enough to cause control problems. Mine squeaks when it needs grease and I clean if off and re grease, both the ball and the hitch. Can't imagine trailing across America at 75 mph with A DRY HITCH, THAT'S ASKING FOR TROUBLE,IMO. I have made a bunch of trips out west and go 5000+ miles before unhitching my trailer, it can't go that long metal to metal without wearing out and possibly coming off the ball!! I've done a bunch of trailing, your nut's if your on our highways with a dry hitch and a danger to the rest of us.
[Re: Challenger 1]
#1387569
02/14/13 10:23 PM
02/14/13 10:23 PM
hulmule
northeast ohio
ive run dry before and seen where it had started to grind against the ball. understand grease collects dirt but clean and regrease. you repack your wheel bearings dont you? how hard is it to smear grease on a trailer ball? grease and be safe !! tube of grease $5
[Re: hulmule]
#1387570
02/14/13 10:54 PM
02/14/13 10:54 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
Well, darned, I put over 150,000 miles on my truck and trailer when I was hauling cars and another 30,000 all those years racing, I never put a drop of grease on the ball. Same ball (I'm a cheap bum) and the trailer coupler was the same one as well. I did have to change the coupler one time after I let someone borrow my trailer and he bent the tongue and coupler. Didn't notice any wear on the coupler, and the chrome was still good on the ball. It was probably the quality of the chrome on the ball that "saved" me. I just hate to think of all those "unsafe" miles I logged on my truck and trailer without greasing the ball. However, given the current quality of available parts around these days, I would probably grease the ball if I was going to do much towing now. Gene
[Re: m88mark]
#1387572
02/14/13 11:32 PM
02/14/13 11:32 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
We have some goose neck trailers at work and we started using them dry by mistake(just didn't think about it) when they were new. It didn't take long for them to have metal shavings in the bed. It was amazing how much more quite they were once we greased them. We have a grease gun in the warehouse and just give them a squirt when we think about it now, no problems.
68 Barracuda Formula S 340
[Re: HotRodDave]
#1387574
02/15/13 12:05 PM
02/15/13 12:05 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I hire a staff of properly trained professionals to care for my balls...
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: HotRodDave]
#1387576
02/15/13 07:14 PM
02/15/13 07:14 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
for the first time in internet history, this thread is perfectly fine without pictures.
