Re: Biggest Valve Size in Stock Aluminum Hemi Head
[Re: Husker1]
#1387181
02/14/13 05:25 AM
02/14/13 05:25 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
My stageV have 2.3I and 1.9E with the 4.5 bore
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Dragula]
#1387183
02/14/13 03:09 PM
02/14/13 03:09 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
Should the question be, What is the biggest valve/camshaft combination I can run? Playing with tappet lift, times the rocker arm ratio, during the overlap phase, was very interesting.
[Re: LaRoy Engines]
#1387184
02/14/13 03:49 PM
02/14/13 03:49 PM
Posts: 12,386 Taxes & Virus's R-US, NY
Dragula
Cam selection is cam selection...Bigger valve is more flow at lower lift regardless of cam. He will need as much flow as he can get with that many cubes, and I would suggest the full CNC port on the heads. Saved the money up front by buying stock heads, now its time to pony up for the flow the engine will need.
My experince on playing the cam game, got me a ton of worn out parts...Valve guides, the seats, lash caps, push rod tips, all kinds of stuff wears out rather quickly with high lift cams and some street miles on them...I should know!
Big cams and overlap are great, but it all depends on your intended purpose. Seems like Bullet cams is the way to go these days, I would call them with all the flow numbers.
[Re: Dragula]
#1387185
02/14/13 10:09 PM
02/14/13 10:09 PM
Posts: 6,389 nielsville, minn.
quickd100
nielsville, minn.
I agree, I called Bullet cams gave them all the engine/head flow info. I also told them I wanted some gentle lobes that wouldn't beat the valve train to death. They ground me a great cam, haven't had ANY problems and the motor make fantastic power and torque.Dave
