What is the biggest valve size that I can put in a new set of Mopar aluminum hemi (gen 2) heads? I am building a 572 pump gas engine (4.500 bore) and thought if possible going larger than the stock 2.25 would help some with the air flow requirement. I don't have the cam picked out yet but will be running a solid roller.
