Re: Engine crank issue...I'm scratching my head on this...
[Re: mopartony]
#1386997
02/13/13 04:32 PM
02/13/13 04:32 PM
Guitar Jones
[Re: Cab_Burge]
#1387000
02/13/13 04:39 PM
02/13/13 04:39 PM
Posts: 4,421 in a chair
mopartony
in a chair
It cranks freely. When I turn the MSD on is when this issue happens. It is a 16V system, it cranks. The battery is fully charged, been on float charge in controled environment so should not be an issue there. I will pull all plugs and see what comes out. Thanks and keep them coming.
[Re: mopartony]
#1387001
02/13/13 05:20 PM
02/13/13 05:20 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Weak battery.
With no charger or anything check the voltage. It should read at least 16.5 volts if fully charged. Then just turn the MSD on and check the voltage again. It should still read at least 16 volts.
If it flunks these test either your charger or battery is dead.
Leon
[Re: mopartony]
#1387005
02/13/13 07:33 PM
02/13/13 07:33 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
Sounds like a battery issue...FWIW I just killed my third 16 volt battery this weekend. I believe due to the charger not going into "float" mode as all show signs of overcharging. 16 Volt batteries wont work well at much under 16 volts..
[Re: mopartony]
#1387007
02/14/13 11:57 AM
02/14/13 11:57 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
fuel hydrolocked motor, that sounds expensive
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1387008
02/14/13 11:58 AM
02/14/13 11:58 AM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
Change your oil!!!! It's probably all gassed up!
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
