What isthis factory aluminum big block intake #2836150? #138653
10/19/08 12:53 PM
10/19/08 12:53 PM
Sterling Heights, Michigan 483...
daniel_depetro Offline OP
It is supose to be a factory piece and has CHRY2836150 stamped on it like a production piece. It is sup[pose to be for a big block and it is aluminum?
Is this for B or RB engines?
Is this a early intake?
Some type of industrial or truck intake? (not sure why they would use aluminum?)
It sure looks like a semi high rise performance part to me.
Is it a good piece or just scrap aluminum?
I check my "white books" and didn't come up with anything.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
Re: What isthis factory aluminum big block intake #2836150? [Re: daniel_depetro] #138654
10/19/08 01:26 PM
10/19/08 01:26 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
looks like a ch4b to me. i like'em. probably won't make the power that the newer rpm manifolds can, but they're decent for street use.
Re: What isthis factory aluminum big block intake #2836150? [Re: lewtot184] #138655
10/19/08 04:15 PM
10/19/08 04:15 PM
Gateway to the West.
hemi_harvester Offline
More than likely a Edelbrock manifold..the PN was used as an early Direct Connection part.
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: What isthis factory aluminum big block intake #2836150? [Re: daniel_depetro] #138656
10/19/08 04:51 PM
10/19/08 04:51 PM
AndyF Offline
AndyF  Offline
An early Edelbrock intake manifold sold over the counter as a Hustle Stuff part. Hustle Stuff was the performance program before Direction Connection which was before Mopar Performance.
Re: What isthis factory aluminum big block intake #2836150? [Re: daniel_depetro] #138657
10/19/08 05:11 PM
10/19/08 05:11 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
NOTHING more than a lite-weight alum stocker intake. I would put that on eBay WITH that part #. Maybe someone is searching for that specific part. I have a COUPLE of "part # searches" going on eBay every day.
Re: What isthis factory aluminum big block intake #2836150? [Re: daniel_depetro] #138658
10/19/08 06:04 PM
10/19/08 06:04 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
As posted above, that's an Edelbock CH4B that someone has ground all aftermarket ID markings off it, only leaving the Hustle Stuff part #.
It flows more and the ports are larger than stock.
The goal is for 'Stealth', make it to appear and pass for a stock intake. The most tell tale sign that gives it away is the coil is not in the OEM location.
The CH4B is the perfect intake for a day two resto.
Re: What isthis factory aluminum big block intake #2836 [Re: BeEtLeJuIcE !] #138659
10/19/08 06:22 PM
10/19/08 06:22 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
BS
Good in between manifold. Much better than stock or the Performer intakes. CH4B (RB) and DP4B (B) engines are the RB/BB version of the LD small block series.
Re: What isthis factory aluminum big block intake #2836 [Re: MoparforLife] #138660
10/19/08 06:31 PM
10/19/08 06:31 PM
The guy is asking $200.00, which is a little high but I wasn't sure what it was either.
Thanks guys.
I guess I'll stick with my Performer RPMs.
I also saw a Mopar dual plane intake on eBay that looked identical to my Performer RPM intakes.
Are these a Mopar knock off, or did Edelbrock make them and stamp the Mopar name on it?
I was going to buy it, however it seems the Performer RPMs are hard to beat for the money ($200.00 shipped on eBay).
I liked the fact that It said Mopar instead of Edelbrock though, but didn't want a lesser intake because of it.
Re: What isthis factory aluminum big block intake #2836 [Re: daniel_depetro] #138661
10/19/08 06:39 PM
10/19/08 06:39 PM
Upper Midwest
Upper Midwest
You are more than likely looking at a dual plane M1 with the Mopar logo. Not the same manifold. M1 not made by Edelbrock either as far as I was told at Edelbrock unless the vender has changed.
Re: What isthis factory aluminum big block intake #2836 [Re: MoparforLife] #138662
10/19/08 07:11 PM
10/19/08 07:11 PM
Re: What isthis factory aluminum big block intake #2836150? [Re: daniel_depetro] #138663
10/19/08 07:51 PM
10/19/08 07:51 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Eddy CH4B . The coil location gives it away.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: What isthis factory aluminum big block intake #2836 [Re: gamagoat6x6] #138664
10/19/08 07:55 PM
10/19/08 07:55 PM
Upper Midwest
Upper Midwest
The CH4B and DP4B have been out of production for many eons. If you are reffing to the ones on eBay in question. His or the one in question is definitely either a CH or DP4B. In the picture it looks to be the narrower DP4B model for the BB, not the RB engines.
Re: What isthis factory aluminum big block intake #2836 [Re: MoparforLife] #138665
10/19/08 08:14 PM
10/19/08 08:14 PM
Florida STAYcation
Florida STAYcation
HORSEfeathers !! .... there is NO WAY that this intake is near the Perf piece of the Performer intake.
I hope you are better at HORSES than IDing intake manifolds !
Re: What isthis factory aluminum big block intake #2836 [Re: BeEtLeJuIcE !] #138666
10/19/08 09:00 PM
10/19/08 09:00 PM
Upper Midwest
Upper Midwest
The DP & Ch series will run circles around Performer which being little if any better than the stock iron version only lighter. Been around this along time and ran those manifolds back in the day they were available and had direct comparisons. In shor ththe performer is nothing more than a glorified aluminum stocker.
Re: What isthis factory aluminum big block intake #2836 [Re: MoparforLife] #138667
10/19/08 09:34 PM
10/19/08 09:34 PM
Florida STAYcation
Florida STAYcation
The CH4B and DP4B ...will indeed run-circles around the Performer and Perf-rpm ... as it goes down-in-flames
If what you say is true ... then why did Eddie do all that new R&D in the Performer ...and not just copy the old design ?
Back in the day ? .... I used to pick up stuff AT the Hustle-Stuff and then the D C warehouse ! What do I know about the DC and MP product? ... I used to be a vendor that sold parts to Mopar.
Now if you show me a published test by a reliable source that shows that my statement is in-error ...I will issue you an apology.
Re: What isthis factory aluminum big block intake #2836 [Re: BeEtLeJuIcE !] #138668
10/19/08 09:34 PM
10/19/08 09:34 PM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
I think you need to look again my friend. This manifold was compared in Hot Rod manifold to several others. It stood toe to toe to the Edelbrock Performer. The Performer RPM outperformed it a wee bit on the upper end but the CH4B numbers were very comparable, especially at low and mid RPM levels. This manifold is usually found cheaper around swap meets and such and works well at idle and off idle acceleration. It wouldnt be my final pick on a mostly week end drag car but the Performer isnt any better.
Re: What isthis factory aluminum big block intake #2836 [Re: gomangoRTSE] #138669
10/19/08 09:50 PM
10/19/08 09:50 PM
Upper Midwest
Upper Midwest
Our track performance was better than the Performer - that is what counts - not Dyno numbers.
Not as good as the RPM or the Torqer 2 but better than the Performer.
Re: What isthis factory aluminum big block intake #2836 [Re: gomangoRTSE] #138670
10/19/08 10:06 PM
10/19/08 10:06 PM
Florida STAYcation
Florida STAYcation
I am not familiar with the specifics of these tests .... although I have heard that they have been done. From the rumblings I heard ... the Holley SD shined ...correct?
BUTTTTT .... I would STILL like to see those tests that show the CH4B running "circles" around the Performer 440.
And my friend ...I also ask you ...why would Eddie come out with a product that was UNequal to a product that they came out with YEARS ago ?
Re: What isthis factory aluminum big block intake #2836 [Re: BeEtLeJuIcE !] #138671
10/20/08 07:00 AM
10/20/08 07:00 AM
Upper Midwest
Upper Midwest
I do not still have time slips from 35 years ago. This is all coming from experience not book reading. The Performer (not Performer RPM which is later issue & a better manifold) was available at the same time as the CH and DP series intakes as an upgrade. Much like the LD series was available at the same time as an upgrade from the small block Performer. Or as in the now days the Std. Performer (which is still produced) to the RPM.
Do what you want.
PS: they worked a lot better on the dirt tracks too. But who cares those days are long gone. This is all coming from experience not book reading.
AS for the horses we have many championships, Association ROM's, high points, and state awards there, so they have been good to us.
Re: What isthis factory aluminum big block intake #2836 [Re: MoparforLife] #138672
10/20/08 08:03 AM
10/20/08 08:03 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Yes its a RPM with the Mopar logo. The MP heads are RPMs with a straight plug too. Eddy is also casting the new Hemi heads all though they only sell them through MP.
