Bolt source #1386324
02/12/13 08:39 PM
02/12/13 08:39 PM
STL ,MO
Handygun Offline OP
Handygun  Offline OP
STL ,MO
Anyone know where to get the 5/8 bolt w/13-16 hex head that is the thrubolt on the shackle for leafsprings like on my 91 R/C? the head is accessed thru a hole in the frame.
Re: Bolt source [Re: Handygun] #1386325
02/12/13 08:55 PM
02/12/13 08:55 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
try fastenal---they are in a town near you.....bob
Re: Bolt source [Re: Handygun] #1386326
02/12/13 10:25 PM
02/12/13 10:25 PM
scratchnfotraction Offline
i may have a couple shackle bolts from all of the chassis work I have done latly.
I look in the shed and measure some to see if i have that size.
do you need any shackles with the bolts?
Re: Bolt source [Re: scratchnfotraction] #1386327
02/12/13 11:01 PM
02/12/13 11:01 PM
STL ,MO
Handygun Offline OP
Handygun  Offline OP
STL ,MO
No Im good on shackles, Just need the bolts. Let me know what you find and thanks. I really dont want to enlarge existing holes to run a generic 15/16 head bolt, slimmest socket in 15/16 that I have is .1258 o/d which is .0258 bigger than my biggest drill bit
Re: Bolt source [Re: Handygun] #1386328
02/12/13 11:59 PM
02/12/13 11:59 PM
do these look like them?
i measure a 5/8 shank, 13/16 socket for bolt,15/16 socket for nut.
IIRC,I did have to use a thin wall socket to fit the inside 13/16 hex.
IIRC you can slip a wrench down from the top between the frame and spring mounting bracket to hold the 13/16 end.
I use the air chisle with a point punch to drive the bolt out, then buff the bolt and clean bushing sleeve for the install.
Re: Bolt source [Re: Handygun] #1386329
02/13/13 03:34 AM
02/13/13 03:34 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Local spring shop might be able to help. Also try contacting suspension lift companies as they have hardware for leaf spring swaps
