my 400 street motor
#1385852
02/11/13 09:14 PM
02/11/13 09:14 PM
Posts: 2,449 nc
earthmover
nc
well working on the 400 like to see what you guys think of the build and how you think it will run.. stock stroke,rods,and pistons...cran cam hyd. 504/528 cut on 112 going in at 106...tm6 intake clean and matched, with 950 hp carb...heads are 906 little port work, factory oil pan cut and made to a deep pan, going to install baffels..also going to add no more then 150 shot of nos...727 , 3000 verta ,456 gears with ss duster ,70 duster ....so what do you guys think it will do ???? pistons are 70th in the holes, will have headers.... here is a link to the build as it is being done.. http://www.forabodiesonly.com/mopar/showthread.php?t=205404
Re: my 400 street motor
[Re: WO23Coronet]
#1385854
02/11/13 10:27 PM
02/11/13 10:27 PM
Posts: 2,449 nc
earthmover
nc
[Re: WO23Coronet]
#1385855
02/12/13 03:12 AM
02/12/13 03:12 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Sounds like a stout build on the cheap! WAG on performance, high 11's on motor, high 10's on spray? Apparently the stock cast pistons can take quite abit of SAB ($h/t and abuse). When do you think you'll be able to run it?
I think you may be a little optimistic, here. I hope it runs good and don't want to rain on anyones parade, but what I see is a stock 400, probably around 8:1 @ the most, with stock iron open chamber heads, and some miss-matched bolt on stuff. Not trying to be a buzz-kill, but at the same time lets not set the guy up for a big dissapointment. My guess would be closer to Mid/high 13's on motor, with mid 12's on the bottle. IMO: Might not be any faster, but would likely be just as fast and much more drivable with a 750 carb. Would run better with a dual plane intake. It may jump out of the hole with the deep gears, but the motor is definatley not set up to run a gear that deep and it will run out of steam quick.
My advice: don't expect too much. Whatever it does.... Have fun with it!
[Re: StealthWedge67]
#1385857
02/12/13 11:08 AM
02/12/13 11:08 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I agree its not a very good combo at all . No ofense meant but it is a very low comp eng that dont need a single plane intake or a 950 carb. Just not a well thought out combo but I do understand you may be just throwing it together to have some fun. My sons 72 Dart is a .030 over 400 with Eddy RPM heads and the MP .557 cam. It has 10.6 comp with KB pistons and uses the RPM intake with a 750 DP. It weighs about 3550 with him in it and has run 11.40's @ 117 in good air with 3.91's. The 400 can run good without stroking it but it needs a piston to get some comp. Good luck , Ron
[Re: moparmafia]
#1385862
02/12/13 02:28 PM
02/12/13 02:28 PM
Posts: 4,255 Canada
WO23Coronet
Canada
Seems like a decent combo to me, the only thing that doesn't fit is the "doggy" compression. Single plane, high stall, 4.56's, 3200 lbs, ported heads…I bet it will be suprisingley quick. He has a similar combo to the Mopar Performance Duster that was used to test the MP cams years back, and it was in the 11's. I still think the car will touch high 11's if the chassis is set up right and everything is just so. It also could be a high 12 car if the chassis is out of whack https://board.moparts.org/ubbthreads/show...e=1#Post7538803
#1385866
02/12/13 04:01 PM
02/12/13 04:01 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Some of you guys are not being POSITIVE ....
Ahhh, the new and more POSITIVE JohnRR..... LMAO. I think I miss the old John!
Blame my lady friend , she is always riding me for not looking at the world thru rose colored glasses
[Re: JohnRR]
#1385867
02/12/13 04:48 PM
02/12/13 04:48 PM
Posts: 6,780 Alabama
Mopar-Al
Alabama
JohnRose-R I don't see it, my glasses fogged up when I even thought it
[Re: earthmover]
#1385869
02/12/13 09:24 PM
02/12/13 09:24 PM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
You have to remember.................there were lots of factory lo-compression motors that got MP cam stuffed into them, a single-plane HSD or TM6/7, headers, a holley and then they ran hard on the street or strip. How else did the wedge motors build any street credibility since even the 69-71 motors with 906's weren't as rated from the factory either.
The biggest booger in the soup is the really soft low-end torque from the lack of compression. High stall and lots of initial mech. advance will help.
