my 400 street motor #1385852
02/11/13 09:14 PM
02/11/13 09:14 PM
nc
E
earthmover Offline OP
E
nc
well working on the 400 like to see what you guys think of the build and how you think it will run..
stock stroke,rods,and pistons...cran cam hyd. 504/528 cut on 112 going in at 106...tm6 intake clean and matched, with 950 hp carb...heads are 906 little port work, factory oil pan cut and made to a deep pan, going to install baffels..also going to add no more then 150 shot of nos...727 , 3000 verta ,456 gears with ss duster ,70 duster ....so what do you guys think it will do ???? pistons are 70th in the holes, will have headers....
here is a link to the build as it is being done..
http://www.forabodiesonly.com/mopar/showthread.php?t=205404
Re: my 400 street motor [Re: earthmover] #1385853
02/11/13 10:20 PM
02/11/13 10:20 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Sounds like a stout build on the cheap! WAG on performance, high 11's on motor, high 10's on spray? Apparently the stock cast pistons can take quite abit of SAB ($h/t and abuse). When do you think you'll be able to run it?
Re: my 400 street motor [Re: WO23Coronet] #1385854
02/11/13 10:27 PM
02/11/13 10:27 PM
nc
E
E
nc
well I was hoping to have all the parts to finish it here soon, but someone had other plans for me over the weekend...I own a dump truck and someone stole the batteries out of it this weekend off the job site which set me back 425.00 so its going to come just a little more time in it..i have to put the heads in the shop to have a valve job done, pick up a oil pump,and a few gaskets...I have most all the other parts...have to have the gear set up..so not long ..will keep this updated
Re: my 400 street motor [Re: WO23Coronet] #1385855
02/12/13 03:12 AM
02/12/13 03:12 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I think you may be a little optimistic, here. I hope it runs good and don't want to rain on anyones parade, but what I see is a stock 400, probably around 8:1 @ the most, with stock iron open chamber heads, and some miss-matched bolt on stuff. Not trying to be a buzz-kill, but at the same time lets not set the guy up for a big dissapointment. My guess would be closer to Mid/high 13's on motor, with mid 12's on the bottle. IMO: Might not be any faster, but would likely be just as fast and much more drivable with a 750 carb. Would run better with a dual plane intake. It may jump out of the hole with the deep gears, but the motor is definatley not set up to run a gear that deep and it will run out of steam quick.
My advice: don't expect too much. Whatever it does.... Have fun with it!
Re: my 400 street motor [Re: earthmover] #1385856
02/12/13 11:04 AM
02/12/13 11:04 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The big problem i see is compression. At best it will be 8:1. I don't see high 11's maybe high 12's with the light car and steap gears. then drop a second for the gazzzz. If you can cut the heads a tad you might be able to get 8.5:1. I'd sell the bottle and get ya some boost. That will fix that 8:1 issue.
Coming soon!!!!
Re: my 400 street motor [Re: StealthWedge67] #1385857
02/12/13 11:08 AM
02/12/13 11:08 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree its not a very good combo at all . No ofense meant but it is a very low comp eng that dont need a single plane intake or a 950 carb. Just not a well thought out combo but I do understand you may be just throwing it together to have some fun.
My sons 72 Dart is a .030 over 400 with Eddy RPM heads and the MP .557 cam. It has 10.6 comp with KB pistons and uses the RPM intake with a 750 DP. It weighs about 3550 with him in it and has run 11.40's @ 117 in good air with 3.91's. The 400 can run good without stroking it but it needs a piston to get some comp. Good luck , Ron
Re: my 400 street motor [Re: 383man] #1385858
02/12/13 11:29 AM
02/12/13 11:29 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Some of you guys are not being POSITIVE ....
Re: my 400 street motor [Re: JohnRR] #1385859
02/12/13 11:43 AM
02/12/13 11:43 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have friends that built about the same combo just with a .590 cam and there always low 7's in the 1/8 on motor and hi 6's on a 175 shot. Your car is lighter then there's so I think your going to be ok.
Re: my 400 street motor [Re: JohnRR] #1385860
02/12/13 11:49 AM
02/12/13 11:49 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I didnt go to the abody link, so what all have you done to the car? Carb seems a little steep, but it may suprise a few around here. Gotta get it to hook, then ride it out. If your around 3200 lbs and can manage 375 hp high 11's is doable off the juice around 111/112 mph.
Re: my 400 street motor [Re: Mopar-Al] #1385861
02/12/13 12:54 PM
02/12/13 12:54 PM
Ky
moparmafia Offline
moparmafia  Offline
Ky
My 70 roadrunner complete car with bench seat and air grabber hood went 8.20 in the 1/8 mile with a stock 400 shortblock with 120k miles on it. It had 906 heads with fresh valvejob and had been cut .030. The cam was an old erson .471 lift. I had a coan 4000 converter and 3.23 gears and wore out pep boy radials.I always wondered what the thing would run freshened up with some compression.
Re: my 400 street motor [Re: moparmafia] #1385862
02/12/13 02:28 PM
02/12/13 02:28 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Seems like a decent combo to me, the only thing that doesn't fit is the "doggy" compression. Single plane, high stall, 4.56's, 3200 lbs, ported heads…I bet it will be suprisingley quick.
He has a similar combo to the Mopar Performance Duster that was used to test the MP cams years back, and it was in the 11's.
I still think the car will touch high 11's if the chassis is set up right and everything is just so. It also could be a high 12 car if the chassis is out of whack
https://board.moparts.org/ubbthreads/show...e=1#Post7538803
Re: my 400 street motor [Re: earthmover] #1385863
02/12/13 02:49 PM
02/12/13 02:49 PM
dogdays Offline
dogdays  Offline
I think it'll be pretty good, I like the advanced cam. Any extra work in the heads will help, too.
IIRC the "950HP" carb flows in the 750 range, Holley didn't name it for its airflow. It'll be fine and worth some power.
R.
Re: my 400 street motor [Re: JohnRR] #1385864
02/12/13 03:01 PM
02/12/13 03:01 PM
Puyallup, WA
Puyallup, WA
Ahhh, the new and more POSITIVE JohnRR..... LMAO. I think I miss the old John!
Re: my 400 street motor [Re: StealthWedge67] #1385865
02/12/13 03:53 PM
02/12/13 03:53 PM
maryland
74yellowduster Offline
maryland
he's savin' a lot of money... this is not an expensive build.
meanwhile, the guy building the gen iii swap... lol
my input is if they can shave the heads down a bit and get the comp to 9:1 this things gonna run like a skeert deer, & get him down the track in the 11's without a problem, not even using the bottle. depending on the rest of the chassis he might even get in the 10's with his 150hp shot.
Re: my 400 street motor [Re: StealthWedge67] #1385866
02/12/13 04:01 PM
02/12/13 04:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Blame my lady friend , she is always riding me for not looking at the world thru rose colored glasses
Re: my 400 street motor [Re: JohnRR] #1385867
02/12/13 04:48 PM
02/12/13 04:48 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
JohnRose-R I don't see it, my glasses fogged up when I even thought it
Re: my 400 street motor [Re: Mopar-Al] #1385868
02/12/13 08:53 PM
02/12/13 08:53 PM
nc
E
E
nc
well thanks for the love those of you that see the big point lo buck build. .and those that don't that's fine to. . there is always that group.. .so here goes...the heads will be cut once they are in the shop,but have to check things before I just go cut them..the idea behind this is to have a car I can get back in and just drive if I want or have a little fun with when I need...not a lot of cash for this build as I am trying to get my chassis car going here soon...lot stuff to learn on that car.. ...this is my old small block car that I have had for about 16/17 yrs now and just want to drive it or something again for those hard days at work and need to vent...lolso I don't plan to sit the world on fire by no means just go out to the store or town and the woods if needed..lol
Re: my 400 street motor [Re: earthmover] #1385869
02/12/13 09:24 PM
02/12/13 09:24 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
You have to remember.................there were lots of factory lo-compression motors that got MP cam stuffed into them, a single-plane HSD or TM6/7, headers, a holley and then they ran hard on the street or strip. How else did the wedge motors build any street credibility since even the 69-71 motors with 906's weren't as rated from the factory either.
The biggest booger in the soup is the really soft low-end torque from the lack of compression. High stall and lots of initial mech. advance will help.
Re: my 400 street motor [Re: Dean_Kuzluzski] #1385870
02/12/13 09:45 PM
02/12/13 09:45 PM
nc
E
E
nc
that's right ..I plan to use either a 10" 3000 verta or a 9.5 50000 lol I have them...dizzy has been rebuild and has light springs in it now, if that don't work weld and lock it out..lol
Re: my 400 street motor [Re: earthmover] #1385871
02/12/13 09:59 PM
02/12/13 09:59 PM
Central NC
gch Offline
gch  Offline
Central NC
The advance will help the idle and I would say low end but with a converter and steep gears low end is really upper mid range lol.
Bolt it together,sort out the tune and have a ball with it.If nothing else it will relieve stress.
