Re: wifes 69 coronet
[Re: Mcat]
#1385809
02/11/13 09:17 PM
02/11/13 09:17 PM
Posts: 75,091 A Banana Republic near you.
JohnRR
what is the stock amp rating want to straighten this out because i'm going to convert it over to electronic ignition
That is how they were originally , turn up the idle to about 1200 and it should stop it , but you don't want to run the idle that high .
[Re: Mcat]
#1385810
02/11/13 09:20 PM
02/11/13 09:20 PM
moparpollack
Lil Herman
Lil Herman
85086
What about doing the mad electric change over? Eliminate the factory connector terminal and wire it solid.
[Re: OhioMopar]
#1385819
02/13/13 04:47 PM
02/13/13 04:47 PM
Posts: 10,232 Someplace you aren't
SomeCarGuy
OP should clean all connections, check ground for VR. Would be wise to swap in YO harness if going to electronic ignition. Maybe run dedicated ground to ECU and VR.
I want my fair share
