I was planning on using the updated engine harness for the electronic ignition.
If the updated harness has the triangle plug for the flat reg (& I would think that it would) & this is going into an earlier car that had a box reg FYI you can trim the sides & redrill 1 mounting hole on a flat 70 up reg & it will nestle neatly into the firewall recess where the box reg once resided. That way you wouldn't have to cut the harness if it's setup for the flat reg.
It does. It has the dual field terminals, the '70 and up style regulator, and the electronic ignition harness built in. Going in a '69 Bee.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
