I need you guys to look and tell me what you think... #1385305
02/10/13 11:38 PM
02/10/13 11:38 PM
SO. CAL.
70blackfish Offline OP
SO. CAL.
I have this motor that has been sitting and it has a small water stain, in one Cylinder, what do you think?
should i run it?
or does it need rebuilding?
Re: I need you guys to look and tell me what you think... [Re: 70blackfish] #1385306
02/10/13 11:44 PM
02/10/13 11:44 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Depends on what you expect out of it. I run motors with worst looking cy walls.
Re: I need you guys to look and tell me what you think... [Re: 70blackfish] #1385307
02/10/13 11:51 PM
02/10/13 11:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know about rebuilding but why not pull the
pistons and hit it with a deglazer and check the rings
before you throw the pistons back in.... JMO
Re: I need you guys to look and tell me what you think... [Re: MR_P_BODY] #1385308
02/10/13 11:54 PM
02/10/13 11:54 PM
maryland
buck440 Offline
buck440  Offline
maryland
i would'nt be scared of that have seen far worse run great.
Re: I need you guys to look and tell me what you think... [Re: buck440] #1385309
02/11/13 12:36 AM
02/11/13 12:36 AM
SO. CAL.
SO. CAL.
just want it as a 10.1 comp. cruiser/driver
Re: I need you guys to look and tell me what you think... [Re: 70blackfish] #1385310
02/11/13 01:33 AM
02/11/13 01:33 AM
Az
Crizila Offline
Crizila  Offline
Az
Run it!
Fastest 300
Re: I need you guys to look and tell me what you think... [Re: 70blackfish] #1385311
02/11/13 02:29 AM
02/11/13 02:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The only reason I suggest pulling the pistons is...
I would think you plan on putting it in a nice ride and
I dont like having to pull a engine back out if something
goes wrong... you have the heads off already...
whats one more day.... yes that spot isnt bad but
it would be my luck it has a issue, plus I'd look
at the bearings... if it all looks good.. put it back
together and have a clear mind about it... but thats... JMO
Re: I need you guys to look and tell me what you think... [Re: MR_P_BODY] #1385312
02/11/13 01:22 PM
02/11/13 01:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Exactly............saw a "finished" block from some [Edited by Moparts - Family Friendly Site - Keep it clean] up here that a buddy was putting together that had bad rust in a couple of cyls and Rick the [Edited by Moparts - Family Friendly Site - Keep it clean] machinest told him it was fine cos the rings would scrub through it and seal fine. I personally would do as Mike says and de-glaze or even ball hone the block. Rings are designed to seal not scrub rust away........
Re: I need you guys to look and tell me what you think... [Re: Thumperdart] #1385313
02/11/13 03:14 PM
02/11/13 03:14 PM
NJ
JCCuda Offline
JCCuda  Offline
NJ
What happens with all the stuff flying around from ball honing 1 cylinder with the rest of the eng. together and what if you go to deep and hit the crank. I wouldn't ball hone without taking the short apart and cleaning everything before re-assembly.
Re: I need you guys to look and tell me what you think... [Re: JCCuda] #1385314
02/11/13 03:17 PM
02/11/13 03:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I wasn`t talking about in car I was refering to it being taken apart then ball honed or better yet although more money, have it properly honed at a shop.
Re: I need you guys to look and tell me what you think... [Re: JCCuda] #1385315
02/11/13 11:47 PM
02/11/13 11:47 PM
gregsdart Offline
gregsdart  Offline
Put the piston with the stain at bdc,turn the motor on an engine stand so the piston is upside down, clean with a scotch brite as best you can, wipe clean, and put it together.
Re: I need you guys to look and tell me what you think... [Re: gregsdart] #1385316
02/12/13 12:14 AM
02/12/13 12:14 AM
Washington State, USA
W
Winchester 73 Offline
W
remember the famouse last words of a project car builder"while im doing that,i may as well,,,,,,"
Re: I need you guys to look and tell me what you think... [Re: Winchester 73] #1385317
02/12/13 01:29 AM
02/12/13 01:29 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have had cylinders that looked like that and just used a ball hone to break the glaze. I would be more worried about the rings on that piston. When I pulled the piston out of mine the rings were stuck where the water was. I used a small screw driver to pop the rings out, removed them , cleaned the grove and the rings up and reinstalled. { Did I say I was cheap } Didn't have any problem with the engine.
Re: I need you guys to look and tell me what you think... [Re: rowin4] #1385318
02/12/13 02:25 PM
02/12/13 02:25 PM
SO. CAL.
SO. CAL.
Thanks guys!
Re: I need you guys to look and tell me what you think... [Re: 70blackfish] #1385319
03/02/13 02:23 PM
03/02/13 02:23 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I think that 70 would look great next to my 67!! My second favorite car here! Sorry but Darryls duster has the #1 spot.. LOL
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
