Re: Help me pick my rear tires
[Re: BEINGmeISaCRIME]
#1385118
02/10/13 09:52 PM
02/10/13 09:52 PM
Posts: 840 southern Idaho
moparcyco
southern Idaho
What about BFG Radial T/A 295/50/15? Same width but you may not like the slightly shorter tire. Hoosier makes some radial tires that have the height and width. On my 70 it has BFG 275/60/15 and they hold up real well.
How much shorter? I think I would rather go slightly skinnier and keep the height.I think my options are few.Was hoping someone had a pic of a combo that looked good.
Is it ok to post pics of other members cars?If not please delete this picture.This is the look I'm after but don't know who's car this is
[Re: fourgearsavoy]
#1385120
02/12/13 12:05 AM
02/12/13 12:05 AM
Posts: 683 Northern NJ
68 Sat
Northern NJ
try these 295/55/15 w 5 1/2 back spacing
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor
1969 Dodge Coronet 500
1956 Desoto Hemi
1955 Chrysler C300
[Re: 68 Sat]
#1385121
02/12/13 01:45 AM
02/12/13 01:45 AM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
These are 275-60-17's on 5.5 b/s wheels. There is no more room. Mastercraft has a newer line out than the Avengers. Sadly these have been discontinued. These measure 11" at the sidewall and almost a full 30" tall. (29.98 spec) You do have to slide the rear back unless you want to trim the front of the 1/4 panel.
...FAFO...
[Re: skicker]
#1385122
02/12/13 02:13 AM
02/12/13 02:13 AM
moparcyco
southern Idaho
I think I'm going to have to go 275-60-15 that looks good on your car.Coker has a 285-70-15 in a bfg but they want $250 a tire.I,m trying to go away from a drag radial,but keep the look I,m planning on 10 to 15 thousand miles a year if I can swing it.Just not much available in these sizes. I bought the +1 espo springs right now without everything in the car the tops of the quarters sit way above the tops of the tires just don't want it to look stupid,and waste money.
[Re: A12]
#1385133
02/15/13 08:57 PM
02/15/13 08:57 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
Don't get T/As... they're such an old-tech tire. Sure they look kind of cool but that's about all they have going for them.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: Secret Chimp]
#1385134
02/15/13 09:25 PM
02/15/13 09:25 PM
Posts: 21,499 N.E. OHIO, USA
A12
N.E. OHIO, USA
Same tech as any 60-series tire out there.....unless you go to a 55-series or less your're not going to see anything that out-techs a basic radial design. Tread pattern, now that's a different tech all together. Then if you want to talk about how a tire is manufactured then you'll have to start looking at Michelin and some other Euro and Pacific Rim manufactures......but not going on my old American Muscle at this point. Only choices are from Goodyear or Firestone IMO and then you need to read the sidewall to see where they are made
So what is out there with leaps and bounds better tech in a 60-series radial tire?
