I need help deciding what will look best for my 69 Bee.It currently rides on 15x10 weld pro stars with 295-65-15 drag radials.I like the way this looks.But i'm having a hard time finding a street tire that is close.What do you guys run?The new rims are wheel vintiques steelies 15x10 with 5.5 offset,this is the same as the welds The cars has +1 springs with the offset rubbing should not be an issue.Pictures of some combos would be great.How about the front also it has 15x6 thought 225-70-15s would look good.Here is what it looks like with the welds and bfgs.Want to get it right the first time thanks guys
