Re: can an old mopar be built 2 outrun this on a racecourse
[Re: savoy64]
#1384529
02/13/13 10:27 PM
02/13/13 10:27 PM
Posts: 2,042 colorado
savoy64
colorado
the Tony Z story is about a self built car--his largest expense was $35000 for a 401 motor built by a nascar engine builder that was known for racing AMC's in his youth---in fact Tony was so broke on his first race he had to borrow a set of nascar road course tires---so i would imagine he did his car for way less than $100,000---maybe even less than $50,000....bob (639)
[Re: topbrent]
#1384531
02/17/13 08:34 PM
02/17/13 08:34 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Did they not put a new engine in that car a few years back? I think it was a 500hp small block.
A new iron curtain drawn across the 49th parallel
[Re: 67autocross]
#1384532
02/19/13 12:59 PM
02/19/13 12:59 PM
Posts: 167 maryland
74yellowduster
maryland
there's a guy here building a track car http://www.forabodiesonly.com/mopar/showthread.php?t=215832for a powerplant, you could go with a stroker (451 or whatever) running 13:1 compression on E85 with a quickfuel E85 carb. big block B or RB with aluminum top end weighs about 470lbs, or a bit less than an original all iron small block with the chassis set up right, light car, powerplant you would smoke him. i dont know about getting your cuda light enough, but it might be doable. abodies get a head start on weight reduction.
[Re: 74yellowduster]
#1384533
02/20/13 01:55 PM
02/20/13 01:55 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
He's building a C-prepared autocross car. Not a really a track car.
John Sandburgs 70 AAR Cuda has own SCCA national in C-prepared ladies class. It's has a fabricated front end, 12" wide rims.... And most of all 40+ years autocross car building experience.
Still, this is not optimized to be an competitive track/road course car.
[Re: 67autocross]
#1384534
02/20/13 02:45 PM
02/20/13 02:45 PM
Posts: 31,077 Oregon
AndyF
Yep, Tim's car got a 427 inch SB which made about 500/500 on the dyno. We pulled the car apart in 2011 to make some changes and it hasn't gone back together yet.
[Re: domingo]
#1384536
02/20/13 05:16 PM
02/20/13 05:16 PM
Posts: 319 Denver
Explodo
Denver
I saw a magazine article that was comparing the mustang, corvette, and GTR on a track with a professional driver and full race logging gear. The mustang was handicapped by the absurdly stupid solid axle that they still put in them. It could hang in the straights and even catch up a little but it lost so much in the corners that it really didn't matter.
Build a light car with a full cage and fully modern and sorted independent suspension and modify it enough to put big tires under it. In the end you'll end up with something akin to the '64 Plymouth that Everham motorsports just did. It will have the outer look of an old car, but it will not be the same car at all.
'67 440 Satellite
[Re: Explodo]
#1384538
02/21/13 12:13 AM
02/21/13 12:13 AM
autoxcuda
So Cal
Mustang has seating for 4 too.
It's base $20K car modified into a car in the ballpark of those two fully designed super cars. One with a $50K msrp for the most basic version, the other $101K.
What they started out at, really isn't a good excuse. But the Mustang seats 4 and more trunk room.
[Re: 67autocross]
#1384543
02/21/13 01:24 AM
02/21/13 01:24 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I don't see why Mitches Challey couldn't whip it with a 100hp boost and some A6 rubber. Those Stangs are well built yes, but not THAT unbeatable.
Mopar to the bone!!!
[Re: 72Swinger]
#1384544
02/21/13 04:29 PM
02/21/13 04:29 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
72Swinger/Emil... Thanks for the suggestive compliment that my Chally could outrun the late model cars... one factor is critical... the "nut behind the wheel" (I'm a little rusty and trying to get back into scene as time/$$ allows).
T/Ake care, Mitch
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
