What do you use as a sealant for fuel fittings? #138440
10/18/08 07:31 PM
10/18/08 07:31 PM
Missouri
bb74swngr Offline OP
mopar addict
mopar addict
Missouri
I am not sure what to use on the threaded fittings for my electric fuel pump and fuel regulator to help seal the threads. Any help or experience would be appreciated.
Thanks everyone, Russ:)
BigBlock 74 Swinger
Re: What do you use as a sealant for fuel fittings? [Re: bb74swngr] #138441
10/18/08 07:49 PM
10/18/08 07:49 PM
Rochester, NY
superb70 Offline
superb70  Offline
Rochester, NY
Teflon tape or pipe thread sealant!
Re: What do you use as a sealant for fuel fittings? [Re: superb70] #138442
10/18/08 08:08 PM
10/18/08 08:08 PM
Missouri
mopar addict
mopar addict
Missouri
Thanks James. Will the stuff at regular hardware stores resist the gasoline ok? I have regular water pipe sealant and tape...will this work?
Russ:)
BigBlock 74 Swinger
Re: What do you use as a sealant for fuel fittings? [Re: bb74swngr] #138443
10/18/08 08:25 PM
10/18/08 08:25 PM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
Tape is probably not a good idea, unless you want to find little pieces of it in your carb...
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: What do you use as a sealant for fuel fittings? [Re: kick_the_reverb] #138444
10/18/08 08:48 PM
10/18/08 08:48 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Ran
Been using tape for years, never have I had that problem! If you use the tape properly you will have no problems.
Re: What do you use as a sealant for fuel fittings? [Re: rrunner] #138445
10/18/08 08:53 PM
10/18/08 08:53 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Shouldn't need any sealer tape or anything else for flare fittings. All the nut does is hold the flare together shouldn't be anything there to leak.
Re: What do you use as a sealant for fuel fittings? [Re: MoparforLife] #138446
10/18/08 09:04 PM
10/18/08 09:04 PM
Missouri
mopar addict
mopar addict
Missouri
I am using compression fittings. There are pipe threads that the fittings screw into and I am concerned that they may leak. I really want to do it right the first time. Thanks so much for the input so far. Still don't feel warm and fuzzy yet about the type of sealer to use.
Any more thoughts....?
Russ:)
BigBlock 74 Swinger
Re: What do you use as a sealant for fuel fittings? [Re: bb74swngr] #138447
10/18/08 09:08 PM
10/18/08 09:08 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Teflon plumbers tape. I"ve used it for a long time with no carb trouble. Just be sparing with it.
Re: What do you use as a sealant for fuel fittings? [Re: stumpy] #138448
10/18/08 09:30 PM
10/18/08 09:30 PM
Missouri
mopar addict
mopar addict
Missouri
Sounds good Richard, I will be careful and give it a try. Thanks so much for the help.
Russ:)
BigBlock 74 Swinger
Re: What do you use as a sealant for fuel fittings? [Re: bb74swngr] #138449
10/18/08 09:32 PM
10/18/08 09:32 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
i use the sealant
Re: What do you use as a sealant for fuel fittings? [Re: bb74swngr] #138450
10/18/08 10:29 PM
10/18/08 10:29 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Russ:)
As long as you don't have any tape hanging off the end, it will be contained in the threads. Just gotta be careful. Like using rtv on gaskets. If your careful and not get sloppy. It's usually not an issue.
Re: What do you use as a sealant for fuel fittings? [Re: Scott Carl] #138451
10/18/08 10:40 PM
10/18/08 10:40 PM
Missouri
mopar addict
mopar addict
Missouri
Funny you should mention the rtv. I have been known to dab a bit to much on my pieces. We had the 440 put together and ready to start. No oil on the dip stick. I was sure I had put the right amount of oil in. Added another quart...no oil on the stick. Again, another quart of oil added...no oil on the stick.
Can you guess where I'm heading with this? I had so much rtv on the pan gaskets (with windage tray) that it covered the hole for the dip stick and was wiping the oil from the stick every time I took it out. Needless to say I had to drain several quarts of oil out once we realized what had happened.
I am very careful now.
Russ:)
BigBlock 74 Swinger
Re: What do you use as a sealant for fuel fittings? [Re: Scott Carl] #138452
10/18/08 10:44 PM
10/18/08 10:44 PM
NPT (pipe threads) need teflon tape or the white pipe thread sealant. flare fittings seal at the flare as mentioned & dont need anything though I've added a shot of WD40 to the threads if I think I'm going to have to open it up again but it's not neccesary.
Re: What do you use as a sealant for fuel fittings? [Re: RapidRobert] #138453
10/18/08 10:53 PM
10/18/08 10:53 PM
Missouri
mopar addict
mopar addict
Missouri
Thanks Robert! You have confirmed my concerns and I plan on trying the tape since I already have some. I will be careful. The WD40 sounds like a good idea as sometimes the threads on the fittings seem to bind a bit once you get down to the last little bit of tightening.
Thanks again!
BigBlock 74 Swinger
Re: What do you use as a sealant for fuel fittings? [Re: bb74swngr] #138454
10/18/08 11:56 PM
10/18/08 11:56 PM
as mentioned start it a hair back from the end & when you cut your piece you have a slight bit of overlap & wrap it in the direction so that when tightening it wants to pull the tape tighter rather than loosening it & with your thumb run it deep into the threads.
Re: What do you use as a sealant for fuel fittings? [Re: RapidRobert] #138455
10/19/08 01:12 AM
10/19/08 01:12 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Many people take pride in proper wrapping of teflon tape. The difference between tape and paste is you do not have to be an expert at it and chances of tape landing in the needle and seat are zero with paste. Even if you perfectly wrap it, someday it needs to come apart too.
LocTite 592 is the best stuff made for pipe threads.
No sealant for flared fittings.
Re: What do you use as a sealant for fuel fittings? [Re: Magnum] #138456
10/19/08 01:25 AM
10/19/08 01:25 AM
Coronado, CA
go-fish Offline
go-fish  Offline
Coronado, CA
AN fittings don't need anything either do they?
70 'cuda: ProCharged 408, Tremec 5 speed, S60,triangulated 4 link, Hydroboost and Wilwoods
Re: What do you use as a sealant for fuel fittings? [Re: go-fish] #138457
10/19/08 05:06 AM
10/19/08 05:06 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Its a flared fitting as well but 37 instead of 45
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: What do you use as a sealant for fuel fittings? [Re: go-fish] #138458
10/19/08 09:21 AM
10/19/08 09:21 AM
the flare does the sealing but I clean the aluminum threads with brake clean then a light dab of 30 wt eng oil because the alum threads are delicate.
Re: What do you use as a sealant for fuel fittings? [Re: RapidRobert] #138459
10/19/08 03:10 PM
10/19/08 03:10 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Go to the local farmers supply or any fuel distribution{portable tanks} supply and get the correct tape...There's a thread tape made for fuel lines...Comes on a roll like teflon tape but this stuff is yellow...We use that tape on all our company trucks that have the bed tanks...
