How to cure wheel hop on a short bed? #1383631
02/08/13 06:03 PM
02/08/13 06:03 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
Just finished putting the new truck to gether and took it for a ride. Nailed the gas and the bucking commenced.I have air shocks that I haven't added air to yet and I don't know if that woul;d make it worse or better. any cures that don't cost am arm and a leg?
Re: How to cure wheel hop on a short bed? [Re: stumpy] #1383632
02/08/13 06:03 PM
02/08/13 06:03 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
Interior.
Re: How to cure wheel hop on a short bed? [Re: stumpy] #1383633
02/08/13 06:17 PM
02/08/13 06:17 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
The important part.
Re: How to cure wheel hop on a short bed? [Re: stumpy] #1383634
02/08/13 06:25 PM
02/08/13 06:25 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Try with air in the shocks. If that works maybe add a couple leafs to the packs. Traction bars, ladder bars caltracs
Re: How to cure wheel hop on a short bed? [Re: 76dodgeboy] #1383635
02/08/13 09:02 PM
02/08/13 09:02 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Clamp the front segments so they cant seperate. My shorty will fry the tires into 2nd gear with 0 wheel hop. When the power is dumped my rearend really squats and the front lifts fast so maybe thats why mine wont wheelhop.
I am truckless..
Re: How to cure wheel hop on a short bed? [Re: 340SHORTY] #1383636
02/08/13 11:11 PM
02/08/13 11:11 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I've used Caltracs before if you don't clamp the springs tight they will make the rear jump up & unload the tires
The Comp engineering set with the rubber joint didn't seem to hit so hard & created less shock
Stumpy I don't know if you want to level it or not But you might want to try cutting the rear segment on the bottom two leaves this with clamping them helps kill wheelhop
I did that on a ShortBed 440 truck that I had that ran 7.40'S 1/8 mile with totally stock suspension budget modified & using drag shocks & /6 springs 29X10.5 Required
I put 200# ballast bar on the very end of the frame with the battery & fuel cell back there too.
Re: How to cure wheel hop on a short bed? [Re: BulletBob] #1383637
02/08/13 11:45 PM
02/08/13 11:45 PM
scratchnfotraction Offline
thats why I like a shackle flip with axle floped ontop of the springs
no wheel hop just spins or hooks.
the axle under set up has always made the rear of a truck jump around,the shackle in stock position flops back and forth as it wheel hops/bounce/rebound
with it flip and the weight loading the shackle and spring it does a much better job controling the wrap up in the springs.
the way the leverage is applied to the spring makes all the difference. IMHO
you can make a traction bar that goes under the u-bolts on top of the spring.
make a plate with an anchor/pivot point and bolt it under the u-bolts on top of leaf spring.
make a rod with a heim joint on one end and a threded stud on the other end.
drill a hole in the front spring mount and use rubbers and washer from a front shock on the stud end and hanger.
done this for a few 4x4s when running the axle under spring,makes a nice traction bar and is up out of the way.
this will elimnate wheel hop on the cheap.
Re: How to cure wheel hop on a short bed? [Re: scratchnfotraction] #1383638
02/09/13 12:59 AM
02/09/13 12:59 AM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
Photos? I'll have my junk back on the road some year and I'll likely need something like this.
Re: How to cure wheel hop on a short bed? [Re: stumpy] #1383639
02/09/13 09:09 AM
02/09/13 09:09 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Stumpy, first off the truck looks great so far.
The clamping of the front segments works good and I even went as far as making traction bars that welded to the bottom of the spring plates. Eliminated the wheel hop but those are band-aid fixes for worn springs and bushings.
I eventually upgraded to new 3/4 ton springs and didn't need any of it. Stock LRE springs are by the numbers 3/4 ton springs with 1/2 ton hardware.
Lastly, throw away those air shocks. What shocks did you run on the old truck?
Re: How to cure wheel hop on a short bed? [Re: redraptor] #1383640
02/09/13 12:06 PM
02/09/13 12:06 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
My dakota would wheel hop badly. especially if it was wet out and traction was even more limited.
I clamped the front section with home made bar stock. and 4 nuts/bolts.
ended all my wheel hop issues.
I can't say that it improved my traction any, because I just use hard street tires, but at least the springs quit hopping around.
**Photobucket sucks**
Re: How to cure wheel hop on a short bed? [Re: redraptor] #1383641
02/09/13 01:37 PM
02/09/13 01:37 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
The same shocks.
Re: How to cure wheel hop on a short bed? [Re: stumpy] #1383642
02/09/13 02:09 PM
02/09/13 02:09 PM
new jersey usa
11secdart Online content
11secdart  Online Content
new jersey usa
I clamped the front spring sections and put on a set of $20 traction bars I got at Carlisle. I also took out the air shocks and put in a pair of B body Rancho shocks I had laying around. It worked well.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: How to cure wheel hop on a short bed? [Re: stumpy] #1383643
02/09/13 11:43 PM
02/09/13 11:43 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Dag, you didn't waste any time on that swap! Time to swap the springs from the old truck?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: How to cure wheel hop on a short bed? [Re: GO_Fish] #1383644
02/10/13 01:03 AM
02/10/13 01:03 AM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
Three weeks start to finish in my driveway. The springs from the old truck wouldn't work because they are rearched 4".
Re: How to cure wheel hop on a short bed? [Re: stumpy] #1383645
02/10/13 01:14 AM
02/10/13 01:14 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Perfect time to mount the axle on top of those springs..
I am truckless..
Re: How to cure wheel hop on a short bed? [Re: scratchnfotraction] #1383646
02/10/13 02:17 AM
02/10/13 02:17 AM
Lehigh Acres, Florida
rickstershemi Offline
the axle under set up has always made the rear of a truck jump around, the shackle in stock position flops back and forth as it wheel hops/bounce/rebound
Mine didn't....haha you witnessed that
Rickster
Re: How to cure wheel hop on a short bed? [Re: stumpy] #1383647
02/10/13 09:05 AM
02/10/13 09:05 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
The same shocks.
Hmmm. Well you don't have to do everything at once.
Re: How to cure wheel hop on a short bed? [Re: rickstershemi] #1383648
02/10/13 11:54 AM
02/10/13 11:54 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Rickster
None of my truck have wheel hopped either
Re: How to cure wheel hop on a short bed? [Re: stumpy] #1383649
02/10/13 11:56 AM
02/10/13 11:56 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Why wouldnt they work
Re: How to cure wheel hop on a short bed? [Re: stumpy] #1383650
02/10/13 09:51 PM
02/10/13 09:51 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
for my 95 sport Dak w/ 5.2 5 speed, I extended the "snubers" on the frame rails down to aboout 3/4" away from the axle tubes. They looked sort of like this... works really well.
Coming soon!!!!
