Re: How to cure wheel hop on a short bed?
[Re: BulletBob]
#1383637
02/08/13 11:45 PM
02/08/13 11:45 PM
Posts: 15,487 Florida
scratchnfotraction
thats why I like a shackle flip with axle floped ontop of the springs no wheel hop just spins or hooks. the axle under set up has always made the rear of a truck jump around,the shackle in stock position flops back and forth as it wheel hops/bounce/rebound with it flip and the weight loading the shackle and spring it does a much better job controling the wrap up in the springs. the way the leverage is applied to the spring makes all the difference. IMHO you can make a traction bar that goes under the u-bolts on top of the spring. make a plate with an anchor/pivot point and bolt it under the u-bolts on top of leaf spring. make a rod with a heim joint on one end and a threded stud on the other end. drill a hole in the front spring mount and use rubbers and washer from a front shock on the stud end and hanger. done this for a few 4x4s when running the axle under spring,makes a nice traction bar and is up out of the way. this will elimnate wheel hop on the cheap.
[Re: scratchnfotraction]
#1383638
02/09/13 12:59 AM
02/09/13 12:59 AM
Posts: 1,226 Cookeville
Chilort
Will Work For Mopars
Cookeville
Photos? I'll have my junk back on the road some year and I'll likely need something like this.
[Re: stumpy]
#1383639
02/09/13 09:09 AM
02/09/13 09:09 AM
Posts: 5,961 Greenville, PA
redraptor
Greenville, PA
Stumpy, first off the truck looks great so far. The clamping of the front segments works good and I even went as far as making traction bars that welded to the bottom of the spring plates. Eliminated the wheel hop but those are band-aid fixes for worn springs and bushings. I eventually upgraded to new 3/4 ton springs and didn't need any of it. Stock LRE springs are by the numbers 3/4 ton springs with 1/2 ton hardware. Lastly, throw away those air shocks. What shocks did you run on the old truck?
[Re: redraptor]
#1383640
02/09/13 12:06 PM
02/09/13 12:06 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
My dakota would wheel hop badly. especially if it was wet out and traction was even more limited.
I clamped the front section with home made bar stock. and 4 nuts/bolts.
ended all my wheel hop issues.
I can't say that it improved my traction any, because I just use hard street tires, but at least the springs quit hopping around.
**Photobucket sucks**
[Re: stumpy]
#1383642
02/09/13 02:09 PM
02/09/13 02:09 PM
Posts: 4,981 new jersey usa
11secdart
new jersey usa
I clamped the front spring sections and put on a set of $20 traction bars I got at Carlisle. I also took out the air shocks and put in a pair of B body Rancho shocks I had laying around. It worked well.
[Re: stumpy]
#1383643
02/09/13 11:43 PM
02/09/13 11:43 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Dag, you didn't waste any time on that swap! Time to swap the springs from the old truck?
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
#1383646
02/10/13 02:17 AM
02/10/13 02:17 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
the axle under set up has always made the rear of a truck jump around, the shackle in stock position flops back and forth as it wheel hops/bounce/rebound
Mine didn't....haha you witnessed that
Rickster
[Re: stumpy]
#1383647
02/10/13 09:05 AM
02/10/13 09:05 AM
redraptor
Greenville, PA
The same shocks.
Hmmm. Well you don't have to do everything at once.
[Re: rickstershemi]
#1383648
02/10/13 11:54 AM
02/10/13 11:54 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Rickster
None of my truck have wheel hopped either
[Re: stumpy]
#1383649
02/10/13 11:56 AM
02/10/13 11:56 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Three weeks start to finish in my driveway. The springs from the old truck wouldn't work because they are rearched 4".
Why wouldnt they work
