318 Poly Trans question #1383208
02/07/13 06:44 PM
02/07/13 06:44 PM
Roseville
FuryousOne Offline OP
Roseville
What trans yoke is used for a 318 Poly?
Re: 318 Poly Trans question [Re: FuryousOne] #1383209
02/07/13 07:41 PM
02/07/13 07:41 PM
Andrewh Offline
Andrewh  Offline
might not understand what you are asking.
it depends on the year, since they were used for many years.
65 and 66 are the slip yoke type, but they are both 2 different types of 727.
earlier it is the ball and trunion.
Re: 318 Poly Trans question [Re: Andrewh] #1383210
02/07/13 08:36 PM
02/07/13 08:36 PM
scratchnfotraction Offline
maybe i dont get the ? either but..maybe this will help.
the trans does not care what 318 is bolted to it and would have the trans yoke for that yr chassis.
3 different output shafts on a 727 auto trans
1) ball and trunion
2) bolt on yoke-short shaft 727
3) slip yoke-long tail shaft 727..same slip yoke for 883-883OD 4-speeds.
yokes can have 3 u-joint sizes
7260 = 2 1/8"
7290 = 2 5/8"
1330 = 3 5/8"
they have conversion u-joints for these 3 mopar yokes as well.
SB 727 interchange on the polly318 and LA318
dont be confused by the polly being called a big block 318, it still has the SB bellhousing bolt spacing.
Re: 318 Poly Trans question [Re: scratchnfotraction] #1383211
02/07/13 08:43 PM
02/07/13 08:43 PM
okla.
sam64 Offline
sam64  Offline
okla.
one lower bell housing bolt hole is different between poly and la.
Re: 318 Poly Trans question [Re: sam64] #1383212
02/07/13 11:06 PM
02/07/13 11:06 PM
Roseville
Roseville
Hi guys...sorry for not being clearer. I have a 65 Poly engine and trans that I am putting into a 24' Dodge Hot Rod that I am building. The trans is a 727, but not sure if it is an "A" or "B". I currently do not have a drive shaft of Yoke. I tried a 904 one but the splines didn't line up.
Thanks for your help.
Re: 318 Poly Trans question [Re: FuryousOne] #1383213
02/08/13 08:18 AM
02/08/13 08:18 AM
slip yoke for 727 is same as a 4-speed
904 is to small as you found out.
any 727/4-speed yoke will fit
I would see what size the rear axle yoke is and pick a 727 yoke to match the u-joint size on both ends of the shaft.
you can use 2 different size u-joints.but having the same size would be best. IMO
Re: 318 Poly Trans question [Re: FuryousOne] #1383214
02/09/13 03:55 AM
02/09/13 03:55 AM
Montana
Y
Yancy Derringer Offline
Y
Montana
What year is the trans out of? The poly should have the early "small" converter pilot, and later (68/ later?) converters have a larger pilot. If so, the converter won't fit your engine.
Re: 318 Poly Trans question [Re: Yancy Derringer] #1383215
02/09/13 03:59 PM
02/09/13 03:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
All 727 converters have the large pilot hub, only the pre-'68 904 has the small hub.
A '65 poly would have been mated to a 727A with a slip yoke and a 7260 u-joint.
Re: 318 Poly Trans question [Re: John_Kunkel] #1383216
02/11/13 06:03 PM
02/11/13 06:03 PM
Roseville
Roseville
Thanks guys...problem solved.
Re: 318 Poly Trans question [Re: FuryousOne] #1383217
02/22/13 06:50 PM
02/22/13 06:50 PM
Roseville
Roseville
Heys guys...one more question, does the 65 318 poly (3-speed manual) trans have the same yoke as the 65 318 poly 727 automatic?
Re: 318 Poly Trans question [Re: FuryousOne] #1383218
02/23/13 04:02 PM
02/23/13 04:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A '65 manual trans wouldn't have a slip yoke like the 727, the manual trans still had the B&T u-joint.
