Re: 318 Poly Trans question
[Re: Andrewh]
#1383210
02/07/13 08:36 PM
02/07/13 08:36 PM
Posts: 15,487 Florida
scratchnfotraction
maybe i dont get the ? either but..maybe this will help.
the trans does not care what 318 is bolted to it and would have the trans yoke for that yr chassis.
3 different output shafts on a 727 auto trans
1) ball and trunion 2) bolt on yoke-short shaft 727 3) slip yoke-long tail shaft 727..same slip yoke for 883-883OD 4-speeds.
yokes can have 3 u-joint sizes
7260 = 2 1/8" 7290 = 2 5/8" 1330 = 3 5/8"
they have conversion u-joints for these 3 mopar yokes as well.
SB 727 interchange on the polly318 and LA318
dont be confused by the polly being called a big block 318, it still has the SB bellhousing bolt spacing.
[Re: FuryousOne]
#1383214
02/09/13 03:55 AM
02/09/13 03:55 AM
Posts: 606 Montana
Yancy Derringer
Montana
Hi guys...sorry for not being clearer. I have a 65 Poly engine and trans that I am putting into a 24' Dodge Hot Rod that I am building. The trans is a 727, but not sure if it is an "A" or "B". I currently do not have a drive shaft of Yoke. I tried a 904 one but the splines didn't line up.
Thanks for your help.
What year is the trans out of? The poly should have the early "small" converter pilot, and later (68/ later?) converters have a larger pilot. If so, the converter won't fit your engine.
[Re: Yancy Derringer]
#1383215
02/09/13 03:59 PM
02/09/13 03:59 PM
Posts: 25,937 Rio Linda, CA
John_Kunkel
Rio Linda, CA
All 727 converters have the large pilot hub, only the pre-'68 904 has the small hub.
A '65 poly would have been mated to a 727A with a slip yoke and a 7260 u-joint.
[Re: FuryousOne]
#1383218
02/23/13 04:02 PM
02/23/13 04:02 PM
John_Kunkel
Rio Linda, CA
A '65 manual trans wouldn't have a slip yoke like the 727, the manual trans still had the B&T u-joint.
