Flywheel Bolts - Do You Reuse?? #1383107
02/07/13 01:20 PM
02/07/13 01:20 PM
Seattle, WA
rss Offline OP
rss  Offline OP
Seattle, WA
I'm interested to see what others think about reusing flywheel mounting bolts.
I'm getting ready to put my 94 Ram 1500 back together and noticed that the FSM recommends new bolts to reinstall the flywheel.
Do you use new bolts everytime, or just wire brush the originals and install with Locktite?
Re: Flywheel Bolts - Do You Reuse?? [Re: rss] #1383108
02/07/13 01:23 PM
02/07/13 01:23 PM
wire brush/clean with brake kleen etc/dry em/blue loctite/torque wrench
Re: Flywheel Bolts - Do You Reuse?? [Re: rss] #1383109
02/07/13 01:23 PM
02/07/13 01:23 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes I would use new bolts for safety. And I would torque them with a torque wrench and skip the locktite if you want a true torque reading and no failures.
Re: Flywheel Bolts - Do You Reuse?? [Re: Challenger 1] #1383110
02/07/13 02:18 PM
02/07/13 02:18 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
X1000%....bolts are cheap, feet, legs and other driveline componets aren't
Re: Flywheel Bolts - Do You Reuse?? [Re: DAYCLONA] #1383111
02/07/13 02:20 PM
02/07/13 02:20 PM
Oakdale, MN
W
weazel Offline
weazel  Offline
W
Oakdale, MN
I've reused them on many different vehicles. Never had a issue!! Like stated, clean them up and reloctite them!
Re: Flywheel Bolts - Do You Reuse?? [Re: RapidRobert] #1383112
02/07/13 02:53 PM
02/07/13 02:53 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Have reused them numerous times with no problems.
Re: Flywheel Bolts - Do You Reuse?? [Re: Challenger 1] #1383113
02/07/13 02:57 PM
02/07/13 02:57 PM
Seattle, WA
rss Offline OP
rss  Offline OP
Seattle, WA
The FSM for my truck actually calls out use of Locktite 242 (Blue) with the new bolts.
Re: Flywheel Bolts - Do You Reuse?? [Re: rss] #1383114
02/07/13 03:02 PM
02/07/13 03:02 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I've reused them.
...well, I've reused modern, ARP high strength flywheel bolts. I've never had originals to re-use.
**Photobucket sucks**
Re: Flywheel Bolts - Do You Reuse?? [Re: weazel] #1383115
02/07/13 03:07 PM
02/07/13 03:07 PM
Penna
70satelliteguy Offline
Penna
"I've reused them on many different vehicles. Never had a issue!! Like stated, clean them up and reloctite them! "
Mike
Re: Flywheel Bolts - Do You Reuse?? [Re: rss] #1383116
02/07/13 04:17 PM
02/07/13 04:17 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
On older stuff I've used them over, much older than 94 though.
Check to see if they are torque to yield bolts. Find out why the FSM reccomends using new bolts.
As said above...new bolts are cheap, legs not so much. Err on the side of safety.
Re: Flywheel Bolts - Do You Reuse?? [Re: rss] #1383117
02/07/13 06:31 PM
02/07/13 06:31 PM
IMGTX Offline
IMGTX  Offline
Like somebody said. New bolts are supposed to be replaced if the FSM says to. Some say they are Torque to Yield, I say they are just cheap. I have used old bolts for Hundreds of thousands of miles and dozens of clutch changes. Older cars used bolts of a better quality IMHO and I clean and loctite them.
BUT
if I were to race it or beat down on a modified engine I would use new ARP bolts plain and simple.
By old I look at anything older than about 85 as old.
Re: Flywheel Bolts - Do You Reuse?? [Re: IMGTX] #1383118
02/08/13 12:11 AM
02/08/13 12:11 AM
Seattle, WA
rss Offline OP
rss  Offline OP
Seattle, WA
Thanks for all the replies.
I've got a new ARP bolt set on order.
Re: Flywheel Bolts - Do You Reuse?? [Re: rss] #1383119
02/08/13 07:47 AM
02/08/13 07:47 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive reused them since the 60s.The last time I did the 65 I did use all new ARPs.I even got their new clutch bolts.Just feels better when Im turning 6700 RPMs.Rocky
Chrysler Firepower
