Re: Flywheel Bolts - Do You Reuse??
[Re: Challenger 1]
#1383110
02/07/13 02:18 PM
02/07/13 02:18 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Yes I would use new bolts for safety. And I would torque them with a torque wrench and skip the locktite if you want a true torque reading and no failures.
X1000%....bolts are cheap, feet, legs and other driveline componets aren't
[Re: RapidRobert]
#1383112
02/07/13 02:53 PM
02/07/13 02:53 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
or just wire brush the originals and install with Locktite?
wire brush/clean with brake kleen etc/dry em/blue loctite/torque wrench
Have reused them numerous times with no problems.
[Re: rss]
#1383114
02/07/13 03:02 PM
02/07/13 03:02 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I've reused them.
...well, I've reused modern, ARP high strength flywheel bolts. I've never had originals to re-use.
**Photobucket sucks**
[Re: rss]
#1383116
02/07/13 04:17 PM
02/07/13 04:17 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
I'm interested to see what others think about reusing flywheel mounting bolts.
I'm getting ready to put my 94 Ram 1500 back together and noticed that the FSM recommends new bolts to reinstall the flywheel.
Do you use new bolts everytime, or just wire brush the originals and install with Locktite?
On older stuff I've used them over, much older than 94 though. Check to see if they are torque to yield bolts. Find out why the FSM reccomends using new bolts.
As said above...new bolts are cheap, legs not so much. Err on the side of safety.
[Re: rss]
#1383119
02/08/13 07:47 AM
02/08/13 07:47 AM
Posts: 21,063 Niles , Ohio
therocks
Niles , Ohio
Ive reused them since the 60s.The last time I did the 65 I did use all new ARPs.I even got their new clutch bolts.Just feels better when Im turning 6700 RPMs.Rocky
Chrysler Firepower
