Need help setting OEMup ring & pinion #1383096
02/07/13 12:49 PM
02/07/13 12:49 PM
Netherlands
72Challenger Offline OP
Netherlands
Hey guys, hope you can help us out.
We recently got in a set of 2.94 OEM ring & pinion set from Mancini and wanted to install it these days. We already noticed there were no given adjustments / settings on the pinion as for the depth etc. so went the trial & error mode to see if we can get the correct pattern.
So far with no luck at all. It gives us no logical idea on how to get it correct. Even seems to be no matching ring & pinion to say at least. The pattern is all over the place, no matter which shims we use.
Maybe we are overlooking something with this OEM set. Any input and/or ideas, tips etc. to get it right in the end?
Thanks a lot guys!
Re: Need help setting OEMup ring & pinion [Re: 72Challenger] #1383097
02/07/13 01:19 PM
02/07/13 01:19 PM
Az
Crizila Offline
Crizila  Offline
Az
It would help if you mentioned what rear end you have? www.randysringandpinion.com has got a ton of info that you can use. Why don't you start there. If your pattern is way off, don't make shim changes less than .010".
Fastest 300
Re: Need help setting OEMup ring & pinion [Re: 72Challenger] #1383098
02/07/13 01:35 PM
02/07/13 01:35 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
A good starting point for a Dana 60 pinion depth is 3.125
8-3/4 /1.875 tapered pinion is 2.726
Re: Need help setting OEMup ring & pinion [Re: B G Racing] #1383099
02/07/13 03:46 PM
02/07/13 03:46 PM
Az
Crizila Offline
Crizila  Offline
Az
and if you are replacing gears in an existing housing and the existing pattern looks good, you will want to start with the existing shim thickness.
Fastest 300
Re: Need help setting OEMup ring & pinion [Re: Crizila] #1383100
02/07/13 04:09 PM
02/07/13 04:09 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Re: Need help setting OEMup ring & pinion [Re: B G Racing] #1383101
02/12/13 08:22 AM
02/12/13 08:22 AM
Netherlands
Netherlands
Sorry for not being complete as for the info.
We had 355 gears but due low tires it gave to many revs so wanted to change to 2.94's. We know the shim thing as in trial & error but how do I explain...
Whichever shims we use the pattern 'wobbles' around like if the ring gear is bent or the r&p doesn't match. Hope you catc what I mean
Re: Need help setting OEMup ring & pinion [Re: 72Challenger] #1383102
02/12/13 08:32 AM
02/12/13 08:32 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Put a deal indicator on the back of the ring gear in the housing.Check the run out.It would be better to do this with the pinion gear out. Possibly the ring gear didn't seat on the carrier properly or a little dirt. Also the carrier may not have seated properly in the housing.
Re: Need help setting OEMup ring & pinion [Re: mac56] #1383103
02/12/13 11:36 AM
02/12/13 11:36 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
You may have to also remove the ring gear and turn it a bit on the carrier.ave
Re: Need help setting OEMup ring & pinion [Re: B G Racing] #1383104
02/13/13 03:08 PM
02/13/13 03:08 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I have 742 carrier for my '68roadrunner and need to put 3.23s in it. Have any idea on the specs for it?
Re: Need help setting OEMup ring & pinion [Re: 52savoy] #1383105
02/13/13 04:17 PM
02/13/13 04:17 PM
Guitar Jones Offline
Factory gears are marked + or - with a number like 0,1, or 2 etc. This is the difference in pinion depth in thousanths of an inch from nominal. In other words a pinion with a +3 on it would need a .003" thicker shim than what the factory pinion depth checking tool would indicate. All basically useless information if you aren't using the factory tools.
Sounds to me like your carrier is warped or you guys used the bolts to pull the ring gear onto the carrier and it's not flush. Factory gears are a little different than aftermarket gears. BTW you still didn't identify what differential this is.
Re: Need help setting OEMup ring & pinion [Re: 52savoy] #1383106
02/13/13 04:19 PM
02/13/13 04:19 PM
742 carrier I start with an .090" shim and adjust from there.
