Page 7 of 10 1 2 5 6 7 8 9 10
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: STEFF] #1382919
04/04/13 12:37 PM
04/04/13 12:37 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
AWESOME numbers,Steff! Congratulations!
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: Labratt] #1382920
04/04/13 01:10 PM
04/04/13 01:10 PM
dogdays Offline
dogdays  Offline
WOWZER! I never expected numbers like that! I want a tamer version for my '64Dog.
R.
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: dogdays] #1382921
04/04/13 02:41 PM
04/04/13 02:41 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Wow, those are some amazing numbers!! Your stuff is always top notch Hey, I think you might need a carb spacer though.
2 kids and a dog
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: TonyS451] #1382922
04/04/13 03:02 PM
04/04/13 03:02 PM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
I asked Steff if he wanted us to keep pushing the engine. We could have tried a bigger Dominator, ran synthetic oil, move cam timing, added a vacuum pump and made 15" of vacuum to make more power. We also could have run the water temperture down to 120* and it WOULD have made more power guaranteed!
Steff wanted to tune it like he is going to run it in his car so 150* water temp, mineral oil and no vacuum pump is how this was tested. We were all pleasantly surprised! Steff doesn't have and he doesnt want a cage in his car. I am positive it will go fast enough to need one so leaning on the engine any harder was kinda pointless.
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: MuscleMike] #1382923
04/04/13 05:46 PM
04/04/13 05:46 PM
Guitar Jones Offline
Damn, just damn, I want that recipe. My car is certified to 8.50 and if need be I'll add the extra bars. Simply awesome numbers, you should be proud of that.
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: Guitar Jones] #1382924
04/04/13 06:54 PM
04/04/13 06:54 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Steff hides bars in his frame rails. Don't let him fool you
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: MuscleMike] #1382925
04/04/13 06:56 PM
04/04/13 06:56 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
So it sounds like they aren't happy/massaged numbers, but with all the tricks you listed above, how much more power would it have made if you we're going for a hero number?
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: WO23Coronet] #1382926
04/04/13 08:31 PM
04/04/13 08:31 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
SICK numbers!!! Congrats, Steff!!
How many CFM was the engine pulling at peak HP?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: sixpackgut] #1382927
04/04/13 08:58 PM
04/04/13 08:58 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
HeHeHe..... He's a tricky devil for sure . Congrats on the great numbers. Sean has been giving me little tidbits here and there, been interesting for sure! Good luck with the new bullet AND the move as well!!!
Randy
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: Dartin] #1382928
04/04/13 11:19 PM
04/04/13 11:19 PM
lino lakes,MN
onebaddakota Offline
lino lakes,MN
These numbers are just amazing. I race a lot with the LSx crowd. I haven't seen any of them making this kind of power short of a big cube LSx motor and aftermarket heads and far bigger cam. Speaking of cams, could you post the specs on it?
10.56 at 125.6, with a 1.43 60 ft. E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: STEFF] #1382929
04/04/13 11:27 PM
04/04/13 11:27 PM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Steff - Can you explain why you went with a belt driven oil pump instead of the factory unit?
Was it just capacity or is there an issue with the factory pumps?
My Cam/Crank Belt Drive eliminates the factory front cover, so the stock pump no longer can be used. Plus I really like the belt driven pump as you can adust the pressure on the low speed side, on the pump and then adjust the high rpm pressure with the pulley ratio, to really dial it in to the motor. Plus, it looks cool! LoL.
Ok thx!
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: Moparmal] #1382930
04/05/13 10:04 AM
04/05/13 10:04 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Magnificent bit of work there.
And outstanding results.
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: tubtar] #1382931
04/05/13 10:12 AM
04/05/13 10:12 AM
tboomer Offline
tboomer  Offline
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: WO23Coronet] #1382932
04/05/13 10:43 AM
04/05/13 10:43 AM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
Gonna find out in about 5 weeks........
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: MuscleMike] #1382933
04/05/13 11:05 AM
04/05/13 11:05 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think you have some serious Engine Masters stuff here Mike.
Mopar to the bone!!!
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: 72Swinger] #1382934
04/05/13 11:08 AM
04/05/13 11:08 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
what are the details on timing?
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: sixpackgut] #1382935
04/05/13 11:39 AM
04/05/13 11:39 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Been hearing lots that the G3 does like too much timing.
Somewhere between 20 and 23
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: MattW] #1382936
04/05/13 12:26 PM
04/05/13 12:26 PM
MN
hemidup Offline
hemidup  Offline
MN
When building the timing curve for our "as delivered" Drag Pak 5.7, it made the best power with 19.5* and was audible at 27*.
Jerry Williams.
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: onebaddakota] #1382937
04/05/13 02:33 PM
04/05/13 02:33 PM
MN
hemidup Offline
hemidup  Offline
MN
Tom, Steff had LSM grind him a custom camshaft which laid down at 7000 rpm. More importantly I'd like to know what improvements Steff made to the chamber of his 6.1 heads??? Port velocity vs cfm flow
#'s is number 1.
Jerry Williams.
Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!! [Re: hemidup] #1382938
04/05/13 06:46 PM
04/05/13 06:46 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Impressive for sure! Better keep this one.
