Is a 7 qt oil pan enough for a hv oil pump? #1382774
02/06/13 11:57 PM
02/06/13 11:57 PM
western PA
Sb Valiant Offline OP
western PA
I was looking at our oil pump and seen that it was a hv pump. I don't know if the 7 qt pan is enough for such a pump? We did have alittle to much oil get up top into the heat cross over in the w-2 heads though.
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: Sb Valiant] #1382775
02/07/13 01:14 AM
02/07/13 01:14 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not a small block but my 470 has an 8-quart pan and I usually run/race w/6-quarts...........
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: Sb Valiant] #1382776
02/07/13 01:38 AM
02/07/13 01:38 AM
British Columbia
toddd Offline
toddd  Offline
British Columbia
I'd get rid of it, you want pressure not volume.
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: Thumperdart] #1382777
02/07/13 08:06 AM
02/07/13 08:06 AM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
I run a HV HP pump on my 440.It has a Moroso 8 qt.I run 7 quts.Its street/strip and never has oil starvation problem.Rocky
Chrysler Firepower
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: toddd] #1382778
02/07/13 08:19 AM
02/07/13 08:19 AM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Hello A 7 qt pan with a HV pump will be OK!We have ran them for years on our drag cars and street cars!(high PRESSURE) is not good!!!! for your bearings. HV IS THE BEST! WE ALWAYS USED MELLING PUMPS (M63HV)MANCINI RACING HAS THEM FOR $70.95 high pressure will push the oil off of your bearings, high pressure is good with a water hose when you or washing the dirt off of your car or truck!!
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: mosweethemi] #1382779
02/07/13 09:25 AM
02/07/13 09:25 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Which is why you don't need a high volume pump.
Kevin
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: Twostick] #1382780
02/07/13 09:44 AM
02/07/13 09:44 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
To the original question; an oil pump pumps oil through clearances in certain places and creates oil pressure. A high volume pump does not pump a single milliliter more oil with a certain oil pressure than a regular pump. If it pumps more oil, the pressure will raise. What the hi volume oil pump does, is retain oil pressure better with bigger clearances or if problems occure. As long as there is oil in the pan for it to suck. I have always used hi vol pumps, the current engine has the limiter at 7800, makes over 1500 hp and has 7qt of oil in the pan.
Plynouth VIP '67 TT IC EFI
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: toddd] #1382781
02/07/13 10:08 AM
02/07/13 10:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Pressure is the by product of flow vs restriction...
you want flow....
to the OP.. if you have a 7qt pan(pan itself), thats
a 8qt system... it will work fine... I had to run
a high volume pump but it has a standard pressure spring
in it... my SB has multiple leak points(mains are
.0028, rods are .0025, roller lifters with EDM holes
and PR oiling) so with the standard pump it was a
bit lower than I liked for a street/strip car
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: mosweethemi] #1382782
02/07/13 10:14 AM
02/07/13 10:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Where do you guys come up with this BS.... whats gonna
push the oil off the bearings... more oil
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: Sb Valiant] #1382783
02/07/13 11:00 AM
02/07/13 11:00 AM
Az
Crizila Offline
Crizila  Offline
Az
7qt pan will work fine with a HV pump. I run 7 qts in an 8qt pan with no problems. FYI, Most of us run more pressure than most oil manufacturers recommend ( 10 psi for every 1000 rpm, starting at around 10 - 15 psi at idle ). I'm about 20 psi over that accross the board. Probably cost me some HP, but it's nice to have a safety margin in case you have a valve train failure, etc. Also why I always run a HV pump.
Fastest 300
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: Sb Valiant] #1382784
02/07/13 11:39 AM
02/07/13 11:39 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
You lost me??? Too much oil in the W2s and oil getting into the heat cross over???
Here you seam to need things broke down so.
Oil is always good.Thats a given!! More oil is good. No oil in the pan is bad. Too much oil is bad and may cost HP.Oil pressure is good. To much oil pressure is bad and may cost HP. Alot of oil flowing threw the motor is good. Too much oil in certain places such as the heads is bad and wasted. Now the type of oil. Some people say light weight and then others say heavy weight. A topic that will be beat again and again. Anouther topic. Crude oil vrs synthetic oil will be beat on for ever. Then the differant brands of oil. My god there are people that will buy 10 dollars a quart oil just because its made by Brad Penn??Oil filter is good. Use a good after market filter that will clean the oil and allow flow. A oil filter will not save a motor that has no oil in it or oil pressure.Plus it will stop big chucks of debree from bearing. But most times way to late.
LETS SUM UP. Oil no mater what brand is good to use in a motor. Commoun sense tells you if you have a six or seven quart pan you put that amount in and 1 more for the oil filter. If you have a oil pump that was on anouther motor and that said motor had issues do not use that pump.Buy a pump that will give you oil pressure and pushs oil threw the motor. Simple
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: slippery440] #1382785
02/07/13 06:00 PM
02/07/13 06:00 PM
western PA
western PA
Thanks guys The oil pump is good but would like to change the spring to get alittle bit better oil pressure. The oil pan is a 7qt home made pan and yes with the filter it makes it a 8qt system. The pan needs some work. I'll make sure to get a good oil filter. The heat cross over on the w-2 heads is a opening in the middle on the intake port side that's about 1 1/2- 2" deep that doesn't go anywhere. We had a decent amount of oil laying up in them. Could be the falt of the intake gaskets and being that they were some home made deals from who knows when. Who ever made them must not of made them right. I think the brad penn oil isn't bad compared to alot of other stuff. Last time I knew they were selling it for 6 bucks a quart.
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: Sb Valiant] #1382786
02/07/13 06:57 PM
02/07/13 06:57 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Put sealant on the threads of the intake bolts will stop the oil seapage.
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: Sb Valiant] #1382787
02/07/13 06:58 PM
02/07/13 06:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sounds like the bottom side of the intake might be
sucking oil in... check the angle closely with feeler
gauges at all 4 corners, top and bottom to make sure
the angle is right... and make sure you close those
stupid cross over ports off
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: jyrki] #1382788
02/07/13 10:43 PM
02/07/13 10:43 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
There it is. Technically, it is pumping more oil, just not to the bearings, just through the bypass, wasting more hp than the standard pump up against the relief.
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: BSB67] #1382789
02/08/13 12:31 AM
02/08/13 12:31 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
HV oil pumps tend to make better pressure @ low RPM with hot oil, the rotor of a HV pump is larger, moving more oil per revolution with the same relief spring pressure setting as a standard pump. Hi volume pumps also remove heat faster than a standard pump at the cost of consuming more HP to drive them. On a tight new engine a standard pump works fine, On a loose engine or a larger engine the Hi volume works best, providing the pan has the capasity for the flow.
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: emarine01] #1382790
02/08/13 09:02 AM
02/08/13 09:02 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Correct
Incorrect, except maybe at lower rpm and pressure when it does not matter. Once your into the relief spring, there is no more oil passing along key engine components. And in fact, the Hv pump is actually putting more heat into the oil when it is beating it around in a circle.
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: BSB67] #1382791
02/08/13 10:57 AM
02/08/13 10:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes IF your in by pass mode BUT if the engine has
larger clearances and other means of oil loss(as in
my case with edm holes and PR oiling) the pump IS moving
more oil.... not everyone can get away with the standard
volume pump and in the case of removing temp... it
does IF its NOT in by pass mode
Re: Is a 7 qt oil pan enough for a hv oil pump? [Re: MR_P_BODY] #1382792
02/08/13 02:12 PM
02/08/13 02:12 PM
An HV pump will pump more oil and, all other things being equal, will put out more pressure.
However, if the oil pressure relief valve opens at, say, 60 psi, and your standard pump will give you 60 psi at cruising speed (or higher), then switching to an HV pump won't give you any more peak pressure; all it will do is funnel extra oil back into the pan. It will give you more pressure at hot idle if that's important, and if a stock pump only give you 10 psi at hot idle and the HV gives you 30, you might want to switch.
On the other hand, if the standard pump only gives you 40-50 psi max (with a 60 psi relief valve), then switching to an HV pump will increase oil pressure at higher speeds, not just at idle or low speed. And in a motor with large bearing clearances, this may very well be the case.
Whether the HV pump will actually increase max pressure depends on the relief valve, bearing clearances, etc. And whether you need or should want more pressure depends . . . .
Re: Is a 7 qt oil pan enough for a hv oil pump? #1382793
02/08/13 05:43 PM
02/08/13 05:43 PM
western PA
western PA
The hv pump we have only put's out a maxium of 55 psi cold and 25-30 psi hot . That's the most it's ever put out no matter what oil weight we try. So I guess it's either change relief valve or spring and get the correct pressure or get a standard oil pump and opening it up like some people do. The oil pan we have is really not worth the effort and time to fix so I am either going to get a 8qt moroso or the milodon 9qt ss pan. So what ever oil pump would be better to use in either application is what I need to use. Anyone reccomend getting a stock oil volume oil pump and open it up and get the right spring for oil pressure? Any power to be had or just a waste of time?
