caltracs on a demon? #1382575
02/06/13 08:07 PM
02/06/13 08:07 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
Got a chance to buy a caltracs set-up for an abody reasonable and I was wondering what type of leaf spring you can use other than the split monoleaf that they recommend? I have super stock springs now but I don't like how high they make my car sit. So I'm just curious what some of the other options and what your guys opinions are?
Re: caltracs on a demon? [Re: Jonnyj00] #1382576
02/06/13 10:04 PM
02/06/13 10:04 PM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
I wouldn't run anything other than a split mono.
Re: caltracs on a demon? [Re: ChrisJohnston669] #1382577
02/06/13 10:19 PM
02/06/13 10:19 PM
maryland
buck440 Offline
buck440  Offline
maryland
i have mine on my wore out factory duster springs. but have not had a chance to try em out.
Re: caltracs on a demon? [Re: Jonnyj00] #1382578
02/06/13 10:34 PM
02/06/13 10:34 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
If your gunna do it,do it right the 1st time and use the whole system.You can thank me later
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: caltracs on a demon? [Re: hemi-itis] #1382579
02/06/13 10:52 PM
02/06/13 10:52 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Re: caltracs on a demon? [Re: StealthWedge67] #1382580
02/07/13 01:22 AM
02/07/13 01:22 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Another thing about the split monos,you can order the ride height directly from Calvert. They build their springs in comparison to stock spring arcs. You can order them in plus or minus stock ride heights. This would help you to lower the back of the car. I have 2" lowering springs on my car.
Re: caltracs on a demon? [Re: buck440] #1382581
02/07/13 01:36 AM
02/07/13 01:36 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I went 1.40 with the pump gas motor in my Duster with wornout stock springs and Caltracs.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: caltracs on a demon? [Re: Eric] #1382582
02/07/13 02:22 AM
02/07/13 02:22 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
My Demon has Caltracs, mono-leafs and leaf spring sliders.
Re: caltracs on a demon? [Re: StealthWedge67] #1382583
02/07/13 02:24 AM
02/07/13 02:24 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: caltracs on a demon? [Re: WHITEDART] #1382584
02/07/13 11:43 AM
02/07/13 11:43 AM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
I believe the ones I have found come with a set of abody springs that the guy ran down in the 10s with in a 68 barracuda. What I was thinking is beings my motor is just a mild low horsepower 383 I could get by with the stock springs until I'm ready to build a motor with more horses. If I was gonna go this route what kind of role do the type of shocks you run play?
Re: caltracs on a demon? [Re: Jonnyj00] #1382585
02/07/13 04:03 PM
02/07/13 04:03 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
Stock springs will work great!!! One thing they give you over mono's is the option of adjustment with spring clamps..............
..........Remember good shocks are HUGE!!!!!
Re: caltracs on a demon? [Re: Jonnyj00] #1382586
02/07/13 09:57 PM
02/07/13 09:57 PM
ill
dennismopar73 Offline
ill
Don't waste your money, the SS springs you have can be adjusted down just by putting a small lower block in !!
we changed and did the whole set up, the car picked up zero ran no better than the ss springs,
Adjusting them can be a pain! unless you 'hit' it right the first time(doubtfull)
Re: caltracs on a demon? [Re: dennismopar73] #1382587
02/07/13 10:14 PM
02/07/13 10:14 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
DO NOT USE SUPER STOCK SPRINGS WITH CAL-TRACS.
I wasted a couple months trying to make that work. It wont.
You can try stock leafs... but if you dont want to waste time -- buy the Calvert mono springs.
Trust me on this---I wasted a lot of time on that experiment !
edit -- this was with CALVERT shocks that they picked out (it wasnt the shocks)
Re: caltracs on a demon? [Re: 493_DART] #1382588
02/07/13 11:31 PM
02/07/13 11:31 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
SS springs on my car mid tens stick......... worked well..........
What were your shock settings????
edit: I took one leaf out of each side........
Re: caltracs on a demon? [Re: 10.90 Racer] #1382589
02/07/13 11:46 PM
02/07/13 11:46 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Tried ALL shock settings......ALL bar settings...clamps and no clamps .....tried all the advice john calvert gave me on the phone too.....ALL the front end tricks.... the car would "porpouse" on the first 10 feet or so and unload the tires .
I dont know how yours are working
im installing ladder bars this spring = no more traction headaches for me
Re: caltracs on a demon? [Re: 493_DART] #1382590
02/07/13 11:58 PM
02/07/13 11:58 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
Hopefully the ladders bars help..... how fast is your car??? Have you checked for binding?? What is done to the front end??
Re: caltracs on a demon? [Re: 493_DART] #1382591
02/08/13 12:14 AM
02/08/13 12:14 AM
Poulsbo, WA
Poulsbo, WA
hey 493dart We had the same problem on my dads duster and my duster. stiff sidewall and innertube cured it all. both our cars hook everytime and nasty consistent in 60' people dont realize how hard a cal trac split mono setup hits. KILLS sidewalls.
Re: caltracs on a demon? [Re: ChrisJohnston669] #1382592
02/08/13 12:27 AM
02/08/13 12:27 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
mine
Re: caltracs on a demon? [Re: 10.90 Racer] #1382593
02/08/13 12:36 AM
02/08/13 12:36 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
no binding-- i went through everything....front and rear...front end loose with lots of travel and Calvert drag fronts. trust me....i tried everything...its been 6.46 in the 1/8 so far .
if i did it again i would do it right the first time and buy the bars / monos / shocks in a package like mentioned above---BUT , i was on a budget like usual and tried to do it with my SS springs
Re: caltracs on a demon? [Re: 493_DART] #1382594
02/08/13 12:39 AM
02/08/13 12:39 AM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
What did you do to the front end??
