Page 1 of 3 1 2 3
Home porting 5.7 hemi heads for Dummies? #1382007
02/05/13 04:44 PM
02/05/13 04:44 PM
gregsdart Online content OP
gregsdart  Online Content OP
Well, I have this set of 5.7 heads from an early (2006?) motor, and would like to clean them up a bit. But as the title of the post says, I don't know much about these heads, or porting.
So the plan is to get what info I can here, and tread very lightly with the die grinder. Anybody care to share?
My thoughts are don't change any general shapes, just clean them up and remove any ridges left by machining operations. Because this is going to be a carbed motor, I plan on leaving the ports on the intake side rough, using as course as a sanding role as I can find. The heads will then get sent out for a valve job with stock valves.
Re: Home porting 5.7 hemi heads for Dummies? [Re: gregsdart] #1382008
02/05/13 04:54 PM
02/05/13 04:54 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
No expert and planning the same thing.
These heads are supposed to be easy because there is no short turn.
One of the reasons they flow so well.
Dulich (sp) did a set, spent little time and basically cleaned them up. They respond very well to a little porting.
And before everybody jumps on me saying there is a lot more to porting than that. I agree just the new hemi would be easier.
Re: Home porting 5.7 hemi heads for Dummies? [Re: gregsdart] #1382009
02/05/13 05:02 PM
02/05/13 05:02 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
These are great for what you are planning to do. Summit does not stock the sanding rolls but if ordered will get them to you on the 18th. If you are just shaping and cleaning up the ports they will give you a nice finish.
http://www.summitracing.com/parts/sai-716296/overview/
http://www.summitracing.com/parts/pow-pow351480
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Home porting 5.7 hemi heads for Dummies? [Re: gregsdart] #1382010
02/05/13 05:28 PM
02/05/13 05:28 PM
MN
hemidup Offline
hemidup  Offline
MN
Here's a cross section if that helps. The head was cut after a pocket port.
Jerry Williams.
Re: Home porting 5.7 hemi heads for Dummies? [Re: gregsdart] #1382011
02/05/13 05:35 PM
02/05/13 05:35 PM
MN
hemidup Offline
hemidup  Offline
MN
A couple pic's of what was taken out with the die grinder.
Jerry Williams.
Re: Home porting 5.7 hemi heads for Dummies? [Re: hemidup] #1382012
02/05/13 05:35 PM
02/05/13 05:35 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I guess there is no pushrod buldge in the older 5.7 heads? Nice cutaway
Re: Home porting 5.7 hemi heads for Dummies? [Re: hemidup] #1382013
02/05/13 05:37 PM
02/05/13 05:37 PM
MN
hemidup Offline
hemidup  Offline
MN
Exhaust port. Don't touch the floor.
Jerry Williams.
Re: Home porting 5.7 hemi heads for Dummies? [Re: hemidup] #1382014
02/05/13 09:59 PM
02/05/13 09:59 PM
thanks guys. So if I see things right, I can thin down the guides, leave the short sides alone, clean up the rest and they ought to work fine with my .580 lift cam. I assume, that due to time at max lift there just isn't much to be gained concerning flow numbers above about .550, and being a street type motor no increase in port volume other than absolutely needed. These are going on a 380 cube 5.7 block motor.
Re: Home porting 5.7 hemi heads for Dummies? [Re: gregsdart] #1382015
02/05/13 10:26 PM
02/05/13 10:26 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
have you put any thought into useing the Eagle head? smaller chamber, larger port and a beautiful casting stock? and same size port as the intakes being made by Ritter
my sandrolled Eagles
Re: Home porting 5.7 hemi heads for Dummies? [Re: sixpackgut] #1382016
02/05/13 10:33 PM
02/05/13 10:33 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
my exhaust port
Re: Home porting 5.7 hemi heads for Dummies? [Re: gregsdart] #1382017
02/05/13 10:37 PM
02/05/13 10:37 PM
MN
hemidup Offline
hemidup  Offline
MN
Greg, Another view of the hand ported G3 intake port.
Jerry Williams.
Re: Home porting 5.7 hemi heads for Dummies? [Re: hemidup] #1382018
02/05/13 10:43 PM
02/05/13 10:43 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Jerry, taking pics without the flash on is key. you have nice pics on your website of them CNC'ed
Re: Home porting 5.7 hemi heads for Dummies? [Re: sixpackgut] #1382019
02/05/13 10:57 PM
02/05/13 10:57 PM
MN
hemidup Offline
hemidup  Offline
MN
Purdy! What valve sizes?
Here's a pic of the very first and only 5.7 closed chamber G3 Hemi heads. Yeah I had the quench pads welded up.
Jerry Williams.
Re: Home porting 5.7 hemi heads for Dummies? [Re: hemidup] #1382020
02/05/13 11:27 PM
02/05/13 11:27 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
stock valves. someday I want to do a manley valve upgrade with dual valve springs and a real cam
Re: Home porting 5.7 hemi heads for Dummies? [Re: sixpackgut] #1382021
02/06/13 12:35 AM
02/06/13 12:35 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Here are some pics of what we did to a set of 09 Eagles. Can't talk about the combination, but these are truly one step below an all out race head. Like a stage 3 street head.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Home porting 5.7 hemi heads for Dummies? [Re: AlexP] #1382022
02/06/13 12:46 AM
02/06/13 12:46 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Very Nice! did you use a buffer on the chambers?
Re: Home porting 5.7 hemi heads for Dummies? [Re: sixpackgut] #1382023
02/06/13 01:03 AM
02/06/13 01:03 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
It's a micropolished chamber. It takes a little bit of work, but well worth the time.
Re: Home porting 5.7 hemi heads for Dummies? [Re: sixpackgut] #1382024
02/06/13 02:25 AM
02/06/13 02:25 AM
MN
hemidup Offline
hemidup  Offline
MN
The stock exhaust valve actually flow'a quite nicely.
Jerry Williams.
Re: Home porting 5.7 hemi heads for Dummies? [Re: AlexP] #1382025
02/06/13 02:31 AM
02/06/13 02:31 AM
SoCal
Brian Hafliger Offline
SoCal
Why? You should try back to back dyno testing that finish with a burr finish...even if power stays the same, your bsfc's will be better and the engine will use less fuel. Just an FYI...
Brian
Brian Hafliger
Re: Home porting 5.7 hemi heads for Dummies? [Re: Brian Hafliger] #1382026
02/06/13 02:34 AM
02/06/13 02:34 AM
SoCal
SoCal
Our valve job using Manley 2.08 x 1.57 valves on an Eagle head:
Page 1 of 3 1 2 3
