Need the link to the latest Gen3 Hemi that made 719hp #1381825
02/05/13 12:37 AM
02/05/13 12:37 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Can't find it anywhere...Need a link
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: Dragula] #1381826
02/05/13 12:41 AM
02/05/13 12:41 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
are you talking about the one Dave young built in the mopar muscle mag?
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: mopar65] #1381827
02/05/13 12:49 AM
02/05/13 12:49 AM
Dragula Offline OP
Dragula  Offline OP
It was in one of the Mopar Mags, and it looked like it was built by Indy, I thought. I did not have time to read it...But I have time now.
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: Dragula] #1381828
02/05/13 01:26 AM
02/05/13 01:26 AM
mopar65 Offline
mopar65  Offline
yes you are right it was Indy cylinder head and Dave young build.the mag is Volume 26 number 04 April 2013 page 28 ( CAN YOU HEMI NOW? PART II
so far the mopar muscle web site sucks for trying to find past tech stuff.
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: mopar65] #1381829
02/05/13 08:55 AM
02/05/13 08:55 AM
The engine was pretty straight forward. It was a 6.1 block, .030 over, stroked to 426 roughly, 10.7:1 C.R, CNC ported 6.4 apache heads, fairly conservative cam, drag pack intake and a 950 HP carb. I was truly impressed with the numbers it made.
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: ] #1381830
02/05/13 01:46 PM
02/05/13 01:46 PM
Dragula Offline OP
Dragula  Offline OP
Thought I saw 10.85:1 compression and didn't have time to catch head flow, cam specs, and cubes...So it was 426 cubes?
I think I gots to have me one..
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: Dragula] #1381831
02/05/13 01:56 PM
02/05/13 01:56 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I think I want one too.... but I want to make 700 hp - then put some boost to it.
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: Dragula] #1381832
02/05/13 02:34 PM
02/05/13 02:34 PM
I think your right about the compression, I dont know why I was thinking 10.7, but still that is a very conservative ratio. I believe the heads had the Indy wind jammer CNC port program and they flowed 370 CFM at peak, dont remember the lift.
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: ] #1381833
02/05/13 02:45 PM
02/05/13 02:45 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I need to find this article.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: AlexP] #1381834
02/05/13 03:27 PM
02/05/13 03:27 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
wow, maybe I should get mine running to find out what mine makes
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: AlexP] #1381835
02/05/13 05:01 PM
02/05/13 05:01 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Mopar Muscle April edition.
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: sixpackgut] #1381836
02/05/13 05:02 PM
02/05/13 05:02 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Yes you do!!!
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: sixpackgut] #1381837
02/05/13 05:06 PM
02/05/13 05:06 PM
Dragula Offline OP
Dragula  Offline OP
Or sell it to me...
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: Dragula] #1381838
02/05/13 05:41 PM
02/05/13 05:41 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Or sell it to me...
you have to many hemis already!
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: sixpackgut] #1381839
02/05/13 06:45 PM
02/05/13 06:45 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I believe 340Rick's motor is a 426" 6.1 with CNC ported heads and a mild roller with around 700HP. Runs 9.90's in his 70 Challenger.
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: sixpackgut] #1381840
02/05/13 06:48 PM
02/05/13 06:48 PM
Dragula Offline OP
Dragula  Offline OP
I also need the link and cannot find it. I want the facts...not inaccurate hearsay.
...And I can always use another Hemi! As much as the newer wedge technology impress's me, they are still just a wedge. And soon, OEM blocks and such won't be that easy to find. Time to switch gears.
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: Dragula] #1381841
02/05/13 07:02 PM
02/05/13 07:02 PM
MN
hemidup Offline
hemidup  Offline
MN
6.1 block
Bore 4.090
Callies Comstar forged crank 4.050
Callies Comstar H beam rods 6.125
Diamond forged flat-top pistons 10.85 final compression
Apache heads CNC'd by Indy cyl
Comp Cams
114 lobe separation
.584 intake lift
.579 exhaust lift
242 intake and 248 degrees duration at .050 lift
Drag Pak Intake
Holley 950-cfm Ultra HP carb
MSD Hemi-6 ignition
TTI Headers 1 7/8 in. primary stepped to 2 in.
Milodon pan and pick-up
Melling oil pump
Jerry Williams.
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: hemidup] #1381842
02/05/13 08:26 PM
02/05/13 08:26 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Is it possible to run a cam with 600+ lift in these 6.1 Hemi's?
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: ProSport] #1381843
02/05/13 09:22 PM
02/05/13 09:22 PM
MN
hemidup Offline
hemidup  Offline
MN
+.600" lift? Some have done it, I don't recomend it.
Jerry Williams.
Re: Need the link to the latest Gen3 Hemi that made 719hp [Re: hemidup] #1381844
02/05/13 09:31 PM
02/05/13 09:31 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
this help ?http://monstermopar.com/forum/index.php?topic=3033.0
