need opinions #1381684
02/04/13 09:00 PM
02/04/13 09:00 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
hi guy's just gitn some opinons on what cam you guy's would run ? here's my engine combo so far. std bore 440 with trw 2295 dome pistons. i beleive they are 11.5 comp. stealth heads milled 0.30 mild port work. team g intake 4500 flange port matched to heads. i will be running proparts 2" primary header's 3500 stall 4.10 gear 28" tire in a 3200lb duster. oh would like to run a 1050 dominator carb whatcha think?
Re: need opinions [Re: buck440] #1381685
02/04/13 09:38 PM
02/04/13 09:38 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
If I were you, I would lose the heavy TRW's. you will be much happier in the long run.
Joe
Without Data, you’re just another guy with an opinion.
Re: need opinions [Re: sr4440] #1381686
02/04/13 09:44 PM
02/04/13 09:44 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
yeah i know buti had em layin round didnt cost much. im budget building right now
Re: need opinions [Re: buck440] #1381687
02/04/13 11:20 PM
02/04/13 11:20 PM
Y-town ohio
68valiant68 Offline
68valiant68  Offline
Y-town ohio
Strip only? Or street-strip?
Re: need opinions [Re: 68valiant68] #1381688
02/05/13 12:53 AM
02/05/13 12:53 AM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
mostly strip ocassional street i was thinkin bout the comp xtreme energy high lift 564 lift hyd.
Re: need opinions [Re: buck440] #1381689
02/05/13 04:58 AM
02/05/13 04:58 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
You may like the MP 590
Re: need opinions [Re: Mopar-Al] #1381690
02/05/13 05:59 AM
02/05/13 05:59 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i had good luck with Hughes cams, good strong power on hotted up stock parts. i'd look at a cam thats somewhere near 250@50 in their collection.
Re: need opinions [Re: buck440] #1381691
02/05/13 12:15 PM
02/05/13 12:15 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
This the cam your thinking about?
http://www.summitracing.com/parts/cca-cl21-229-4/overview/make/chrysler
should work fine degreed in at about 103.
Why only a 3500 stall??
Re: need opinions [Re: buck440] #1381692
02/05/13 12:42 PM
02/05/13 12:42 PM
maryland
74yellowduster Offline
maryland
with that carb intake compression you could probably go .600 lift easy IF you have the right springs, rockers, etc. and can have the pistons cleared to the valves for that lift.
if using stock rockers and dont want to cut the pistons you should probably not go so big and still should thoroghly check the piston/valve clearances
Re: need opinions [Re: Dodgem] #1381693
02/05/13 07:31 PM
02/05/13 07:31 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
yep that's the cam. 3500 stall is what i have laying round at the moment. race season is almost here just wanna have something throwed together to run that'all. till i build my 451. thanks for the reply
Re: need opinions [Re: Mopar-Al] #1381694
02/05/13 07:33 PM
02/05/13 07:33 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
the 590 is mechanical not hyd. right ?
Re: need opinions [Re: buck440] #1381695
02/06/13 06:29 PM
02/06/13 06:29 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
Re: need opinions [Re: buck440] #1381696
02/06/13 06:44 PM
02/06/13 06:44 PM
Middletown, Ohio
Joes66dart Offline
Joes66dart  Offline
Middletown, Ohio
MP 590 is what we run and have been very happy with it. It is a solid lift cam.
Re: need opinions [Re: Joes66dart] #1381697
02/06/13 10:17 PM
02/06/13 10:17 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
thanks. do you guy's think the 509 would make good power with this combo?
Re: need opinions [Re: buck440] #1381698
02/07/13 01:52 AM
02/07/13 01:52 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
yea, ol 509 will be fine. particuly since you have one already
Re: need opinions [Re: SG duster] #1381699
02/07/13 10:05 PM
02/07/13 10:05 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
no im lookin into cams. alway's ran the tried and true 509 but i want a little more. so any advise is apreciated
Re: need opinions [Re: buck440] #1381700
02/07/13 10:17 PM
02/07/13 10:17 PM
gregsdart Online content
gregsdart  Online Content
The 590 will make a lot more power than the 509, and would be my pick. Dial it in very early (102?) due to the tight converter, shift it at 6,000.
Re: need opinions [Re: gregsdart] #1381701
02/07/13 10:21 PM
02/07/13 10:21 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Call Hughes Engines - they are "Mopar only " cam designers.
I run one of their solid flat tappet grinds-----love it .
Re: need opinions [Re: gregsdart] #1381702
02/07/13 10:44 PM
02/07/13 10:44 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
thanks what bout the 557 mp shaft? sorry if i keep askin a bunch of questions but i dont have much mechanical cam exp.
Re: need opinions [Re: 493_DART] #1381703
02/08/13 12:07 AM
02/08/13 12:07 AM
Az
Crizila Offline
Crizila  Offline
Az
Some of the best Mopar cams out there IMO.
Fastest 300
