recent project working on Ricks TS daytona #1381271
02/04/13 04:37 AM
02/04/13 04:37 AM
communist bloc of new jersey
jamesc Offline OP
jamesc  Offline OP
been working on cleaning up some wiring and changing the wiring on Ricks daytona from a lenco to a glide plus adding the wiring for bracket racing. my ribs are killing me from leaning over the bars. pics aren't that great but i was more focused on doing the job.
laying stuff out to get started
this is the front after i rewired it from the inside out, added weather-pack connectors for the coil, fan, water pump and headlights in the nose
delay box and shifter. there's a lot going on here between the box, trans brake solenoid, electric shifter and neutral safety. used a two pin for the TB solenoid and a six for everything else. there's a relay under the shifter to control the shift solenoid. with the connectors you can pull the shifter and box assembly out in a couple minutes.
i cleaned up some of the battery and line lock wiring, there was a real carbuncle there. it's not the best but a lot better than it was.
this is the last big area i have to clean up. all the wiring that was in it was functional but how they arrived there was a little confusing. the fuel pump had a relay running two other relays.
well that's it for now i'm tired
Re: recent project working on Ricks TS daytona [Re: jamesc] #1381272
02/04/13 01:08 PM
02/04/13 01:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Lookin good........... I hear ya about the ribs AND the back, shoulders, elbows etc. Fun stuff indeed but I`d bet you`re WAY better than me which translates into less of those pains for less time............
Re: recent project working on Ricks TS daytona [Re: Thumperdart] #1381273
02/04/13 05:17 PM
02/04/13 05:17 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
What water pump is on that thing. I'm having no luck with my contraption of a cooling system on my Avenger and need to totally rethink it and that setup has me thinking.
Re: recent project working on Ricks TS daytona [Re: FastmOp] #1381274
02/04/13 10:55 PM
02/04/13 10:55 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
LOOKS PRETTY GOOD.ALMOST LOOKS LIKE MY DAYTONA INSIDE. IM HAVING MY CAR REWIRED NOW TOO.
Re: recent project working on Ricks TS daytona [Re: FastmOp] #1381275
02/04/13 11:17 PM
02/04/13 11:17 PM
jamesc Offline OP
jamesc  Offline OP
it's a meziere radiator mount
http://www.meziere.com/ps-1176-1144-wp362.aspx
been at it all day have to get something to eat. just about done, tested everything and no problems...looking to fire it off tomorrow. i'll try to get a couple more pics of the finished product
Re: recent project working on Ricks TS daytona [Re: jamesc] #1381276
02/05/13 09:41 AM
02/05/13 09:41 AM
tboomer Offline
tboomer  Offline
Nice job,James! Can't wait for finished pics!
Re: recent project working on Ricks TS daytona [Re: tboomer] #1381277
02/06/13 05:38 PM
02/06/13 05:38 PM
jamesc Offline OP
jamesc  Offline OP
it's almost done, again sorry for the bad pics
taking out old wiring
after
camera really didn't want to shoot through the windshield. the fiberglass dash that's sitting on the roof covers most all of this anyhow
i could only make the panel so clean without gutting the entire car and that wasn't desired or really necessary
Rick had a local TS racer that does fabrication make up the shifter mount and do some other changes for the trans swap
playing with my new plasma cutter i made up a hook to hang the wheel on
just some other pics of the car
Re: recent project working on Ricks TS daytona [Re: jamesc] #1381278
02/06/13 06:27 PM
02/06/13 06:27 PM
Q
Quicktree Offline
Quicktree  Offline
Q
looks good James, can a brother borrow that glide
