Stripping Down Body #138116
10/17/08 09:05 PM
10/17/08 09:05 PM
440charger70 Offline OP
super street
super street
I am wanting to strip the the body on my Charger down to bare metal due to too much paint an hidden problems. I know that sand blasting is too rough for the metal, how is crushed glass? Too abrasive? Not abrasive enough? Your thoughts are appreciated.
1970 Dodge Charger 440 (NOM) 1971 Plymouth Duster 340 (#'s Correct) 2008 Jeep Wrangler Sahara. Nice Home for sale near Tampa FL http://ruskinonline.com/docs/WimaumaHouse.htm
Re: Stripping Down Body [Re: 440charger70] #138117
10/17/08 09:06 PM
10/17/08 09:06 PM
super street
super street
x
Re: Stripping Down Body [Re: 440charger70] #138118
10/17/08 09:16 PM
10/17/08 09:16 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
We recently stripped down the paint with aircraft stripper.
1968 Road Ruiner Build
I am sure many have had success with media blasting, but I have heard others warping panels by sand blasting, particularly big panels like roofs and quarter panels
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Stripping Down Body [Re: Kam*Kuda] #138119
10/17/08 09:27 PM
10/17/08 09:27 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
had mine blasted but they use a plastibead on the large panels so no warping it will even pull all the filler out.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Stripping Down Body [Re: 440charger70] #138120
10/17/08 09:32 PM
10/17/08 09:32 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Soda blasting or potassium nitrate blasting will remove the paint and not create the heat of sand blasting.
Re: Stripping Down Body [Re: dusturbd340W5] #138121
10/17/08 09:37 PM
10/17/08 09:37 PM
Williamsport, PA
Kingy Offline
Royal Pain
Kingy  Offline
Royal Pain
Williamsport, PA
Blasting? I never blast
Re: Stripping Down Body [Re: 440charger70] #138122
10/18/08 12:49 AM
10/18/08 12:49 AM
AZ - The "dry heat" state
71autoxr Offline
71autoxr  Offline
I had a soda blaster quote me $1700 to do a completely stripped A body convertible. Inside/outside, and all body parts. While I have not had it done, when the time comes I will buy a blaster, and several hundred pounds of soda and blast it myself. I have used Aircraft stripper in the past, messy, dries too fast in AZ, expensive gallon at a time, several applications usually necessary if car has been repainted and needs to be rinsed with water when completed (remember bare metal). Sand is too course and will warp panels, there are other media to use (walnut shells etc) but you might have to look into which ones are safe for body panels.
If you want an inexpensive start, go buy a box of razor blades and a good handle and you'll have most of the paint and primer off in no time, plus you can vacuum it up, put it in a ziplock and impress your freinds. My brother stripped a 71 vette this way and I stripped a 69 dart this way. Only used about a dozen blades. When your done you can use a DA with semi course disc to get the rest.
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Re: Stripping Down Body [Re: 440charger70] #138123
10/18/08 01:29 AM
10/18/08 01:29 AM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
i used aircraft stipper, just be sure to wear gloves and have mask when you apply, once all the paint is gone, you can take da and light sand with 120 grit to prepare for the primer
Re: Stripping Down Body [Re: cornet684me] #138124
10/18/08 09:23 AM
10/18/08 09:23 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
A car painter told me he does not like to paint cars that have been "soda" stripped as there are adhesion problems because of the soda. I am not sure if he was talking about the soda itself or the fact that the soda does not "etch up" the metal like sand or plastic beads do.
I have had others tell me that the soda leaves a film that needs to be rinsed well before priming.
Any personal experiences out there??
Driving modern convenience in classic beauty
