2006 Ram 1500 Fuel Pump Replacement - Advice needed #1380537
02/02/13 11:21 PM
02/02/13 11:21 PM
NC
DCM71cuda Offline OP
NC
I need to replace the fuel pump in my 2006 Ram (5.7L). I have the part, which includes the pump/sending unit ass'y.
I know it requires lowering the tank and removing the old unit from the top of the tank. Having not done this specific job before, are there any specific pitfalls I need to look out for during the job?
My tank is almost completely empty, so that is a plus. Thanks for any help.
Re: 2006 Ram 1500 Fuel Pump Replacement - Advice needed [Re: DCM71cuda] #1380538
02/03/13 12:36 AM
02/03/13 12:36 AM
Kansas
BEINGmeISaCRIME Offline
Kansas
I would say be careful when disconnecting fuel lines as well as electrical connections and EVAP lines coming from the tank, you don't want any of those to break (duh!) It will help to lower the tank some and then disconnect the filler tube from the tank. Usually they are a rubber hose with clamp on them.
Re: 2006 Ram 1500 Fuel Pump Replacement - Advice needed [Re: DCM71cuda] #1380539
02/03/13 12:56 AM
02/03/13 12:56 AM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
I assume it's the same as the 2005. I did mine about a year ago. It wasn't fun.
You will need to understand how to remove the hardlines - both from the vents and the sender. The connection is made with a plastic C-shaped clip that inserts into the female portion of the connector.
To remove the tubes, you have to push DOWN on the top portion with your thumb. This spreads the the feet apart and disengages the lock. So, while pushing down, pull the tube back off the nipple.
Here is what they look like:
http://www.autozone.com/autozone/parts/D...18899_322774_0_
If your truck is anything like mine, the fuel pump retainer lock ring and seat was horribly, and I mean incredibly rusty. I had to do a lot of R&R on it, and it was close to needing a new tank it was so bad. I was surprised.
Aside from that, the job is not too hard. Just go slow and use your wits. If you need help, get a year's subscription for your truck to AllDataDIY
Here are some before pictures in case that helps you get an idea in your mind. You're supposed to take the filler tube off, but I man handled it myself to save a bit of work.
Don't be surprised if your old pump is destroyed in this manner. This was not a result of me working on it, it came apart like this.
make sure you disconnect the battery before doing the work. Don't reconnect it until you are all buttoned back up.
After:
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: 2006 Ram 1500 Fuel Pump Replacement - Advice needed [Re: VincentVega] #1380540
02/03/13 01:56 AM
02/03/13 01:56 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I like to pull the driveshaft out of the way also as it gives you more working room and when I did them on a lift it was one less thing to hit my head on.
Some of the techs would actually pull the bed and do it from the top. And that bed is not as light as we thought. Good luck , Ron
Re: 2006 Ram 1500 Fuel Pump Replacement - Advice needed [Re: 383man] #1380541
02/03/13 10:02 PM
02/03/13 10:02 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
Drop the tank,easier than pulling the box,get a new lock ring&done.
Re: 2006 Ram 1500 Fuel Pump Replacement - Advice needed [Re: GarageDodge] #1380542
02/03/13 10:50 PM
02/03/13 10:50 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
I agree with 383man pulling the drive shaft makes it a lot easier.
