My new RC, and a question or two #1380133
02/02/13 04:35 AM
02/02/13 04:35 AM
Sarcoxie, MO, USA
MoPar Jamie Offline OP
Sarcoxie, MO, USA
Hey guys,
Did some more trading and ended up with an 86 RC 4wd. Was a 360 but now has a 318-4v in it. A little rust through down low but the floors are solid. Interior is a little rough, pulled the armrests and swapped the pass. seat for the drivers. Then threw in an off color one for the passenger to use.
It has Turbines on it with 31s that have great tread.
Anyway the back hatch has been replaced and it sags low on the drivers side. It closes but its way out of line. Looks like the hinges have been replaced as well.
Are there any adjustments that I can make to help re-align it? It needs to go up.
Also, I have a set of 16s to go on it. What metric tire size would I need to match the 31s? Maybe wider but Id like to stick with a 31" tire diameter.
Here is a pic!
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: My new RC, and a question or two [Re: MoPar Jamie] #1380134
02/02/13 04:36 AM
02/02/13 04:36 AM
Sarcoxie, MO, USA
Sarcoxie, MO, USA
Another, notice the drivers side of the hatch mis-aligned.
- MoPar Jamie
1972 Fury III 4dr
Re: My new RC, and a question or two [Re: MoPar Jamie] #1380135
02/02/13 05:09 AM
02/02/13 05:09 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The hinge area on the hatch is probably rotted out there
Re: My new RC, and a question or two [Re: BulletBob] #1380136
02/02/13 10:14 AM
02/02/13 10:14 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Or the hatch is cracked in upper section. That's a pretty heavy non-steel hatch and the cylinders are holding quite a load. P265/70's are a decent sized tire, similar to 31x1050's.
Re: My new RC, and a question or two [Re: buildanother] #1380137
02/02/13 03:03 PM
02/02/13 03:03 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
It's usually the hatch itself coming apart. Keep the hinges lubed.
Re: My new RC, and a question or two [Re: Cooter] #1380138
02/02/13 06:36 PM
02/02/13 06:36 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
As stated 265/70. Its Identical. A 75 will work also. Remember different brands mean slight variations in height but the 70 Is dead nuts with sizing. Id consider Treadwright.com for tires. Great price and quality. This tire is $116 for the 265/70 16. This is the only tread design for that size though.
What are you doing with the turbines
Re: My new RC, and a question or two [Re: 76dodgeboy] #1380139
02/03/13 06:18 PM
02/03/13 06:18 PM
northeast ohio
hulmule Online content
hulmule  Online Content
northeast ohio
what kind of rim can you put on a 84 dodge 4x4 step side , would like to go to 16 . how can you put 16 on a ramcharger?? thought they were different pattern? want to do something on my sons stepside 4x4 thanks
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: My new RC, and a question or two [Re: hulmule] #1380140
02/03/13 08:21 PM
02/03/13 08:21 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You bolt them on! You realize they make 30" rims that could bolt on aswell. Just about Any aftermarket rim with 5x5.5" bolt pattern will fit but backspacing affects that aswell. No diff than putting 15's on a Dart that was 14" stock. Bolt pattern/hub hole size/back spacing is All you need to know.
Re: My new RC, and a question or two [Re: 76dodgeboy] #1380141
02/03/13 11:06 PM
02/03/13 11:06 PM
northeast ohio
northeast ohio
im talking about using a newer dodge factory rim thats 16"
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: My new RC, and a question or two [Re: hulmule] #1380142
02/03/13 11:44 PM
02/03/13 11:44 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Newer Dodge is 5 on 5.5 pattern.
Your truck should be 5 on 4.5 pattern, so you would need to use a lug adapter. But depending on what year wheel you buy you may need a 1.5" spacer/adapter anyway. So you could still run the Dodge wheel.
The down side is once you buy the wheels, and then the adapter/spacers you could just buy an aftermarket 16" or larger wheel of your choosing with the correct pattern and backspace.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: My new RC, and a question or two [Re: hulmule] #1380143
02/04/13 01:17 AM
02/04/13 01:17 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
And I explained the hub hole needs to match. Didn't see where he said 94up wheels.
The steel wheels the center can be made bigger with a torch or have a machine shop do it. The aluminum rims need the same done depending on which rim. 94-01
Hp 80 up 4wd is 5.5
Re: My new RC, and a question or two [Re: 76dodgeboy] #1380144
02/04/13 01:30 AM
02/04/13 01:30 AM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
I wasn't sure how new of a truck he planned on getting a wheel from. So a spacer may or may not be needed.
As to the pattern I still get them confused on the 80's stuff.
Re: My new RC, and a question or two [Re: hp383] #1380145
02/04/13 01:33 AM
02/04/13 01:33 AM
N
NITROUSN Offline
NITROUSN  Offline
N
80 on up is 5 on 5 1/2
Re: My new RC, and a question or two [Re: NITROUSN] #1380146
02/04/13 01:36 AM
02/04/13 01:36 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
^ 4wd
