My new RC, and a question or two
#1380133
02/02/13 04:35 AM
02/02/13 04:35 AM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
Hey guys,
Did some more trading and ended up with an 86 RC 4wd. Was a 360 but now has a 318-4v in it. A little rust through down low but the floors are solid. Interior is a little rough, pulled the armrests and swapped the pass. seat for the drivers. Then threw in an off color one for the passenger to use.
It has Turbines on it with 31s that have great tread.
Anyway the back hatch has been replaced and it sags low on the drivers side. It closes but its way out of line. Looks like the hinges have been replaced as well.
Are there any adjustments that I can make to help re-align it? It needs to go up.
Also, I have a set of 16s to go on it. What metric tire size would I need to match the 31s? Maybe wider but Id like to stick with a 31" tire diameter.
Here is a pic!
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
Re: My new RC, and a question or two
[Re: 76dodgeboy]
#1380139
02/03/13 06:18 PM
02/03/13 06:18 PM
Posts: 1,404 northeast ohio
hulmule
northeast ohio
what kind of rim can you put on a 84 dodge 4x4 step side , would like to go to 16 . how can you put 16 on a ramcharger?? thought they were different pattern? want to do something on my sons stepside 4x4 thanks
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: 76dodgeboy]
#1380141
02/03/13 11:06 PM
02/03/13 11:06 PM
hulmule
northeast ohio
im talking about using a newer dodge factory rim thats 16"
[Re: hulmule]
#1380142
02/03/13 11:44 PM
02/03/13 11:44 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Newer Dodge is 5 on 5.5 pattern.
Your truck should be 5 on 4.5 pattern, so you would need to use a lug adapter. But depending on what year wheel you buy you may need a 1.5" spacer/adapter anyway. So you could still run the Dodge wheel.
The down side is once you buy the wheels, and then the adapter/spacers you could just buy an aftermarket 16" or larger wheel of your choosing with the correct pattern and backspace.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hulmule]
#1380143
02/04/13 01:17 AM
02/04/13 01:17 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
And I explained the hub hole needs to match. Didn't see where he said 94up wheels. The steel wheels the center can be made bigger with a torch or have a machine shop do it. The aluminum rims need the same done depending on which rim. 94-01
Hp 80 up 4wd is 5.5
[Re: hp383]
#1380145
02/04/13 01:33 AM
02/04/13 01:33 AM
Posts: 18,407 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
80 on up is 5 on 5 1/2
[Re: NITROUSN]
#1380146
02/04/13 01:36 AM
02/04/13 01:36 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
