Page 1 of 3 1 2 3
Go ahead and laugh, I'm lazy, Why not? #1379963
02/01/13 11:16 PM
02/01/13 11:16 PM
BDW Online content OP
BDW  Online Content OP
Got tired of dealing with the the mess during oil changes and added this.
Re: Go ahead and laugh, I'm lazy, Why not? [Re: BDW] #1379964
02/01/13 11:29 PM
02/01/13 11:29 PM
Australia
67polara Offline
67polara  Offline
Australia
Accident waiting to happen
Re: Go ahead and laugh, I'm lazy, Why not? [Re: BDW] #1379965
02/01/13 11:32 PM
02/01/13 11:32 PM
scratchnfotraction Offline
I could use a couple of those on my junk,I am lazy as well and the oil change is 1000 miles overdue.
Re: Go ahead and laugh, I'm lazy, Why not? [Re: scratchnfotraction] #1379966
02/01/13 11:40 PM
02/01/13 11:40 PM
Got it on Amazon
Fumoto 101
http://www.fumotousa.com/
I've had 1 on my Mustang for the last 3 yrs and love it.
Re: Go ahead and laugh, I'm lazy, Why not? [Re: BDW] #1379967
02/01/13 11:50 PM
02/01/13 11:50 PM
If it dont leak & the handle stays securely locked in the shutoff position I'd be OK with using one. Who sells em
Re: Go ahead and laugh, I'm lazy, Why not? [Re: RapidRobert] #1379968
02/01/13 11:53 PM
02/01/13 11:53 PM
Re: Go ahead and laugh, I'm lazy, Why not? [Re: RapidRobert] #1379969
02/01/13 11:54 PM
02/01/13 11:54 PM
the house on the left.
cogen80 Offline
cogen80  Offline
handle is spring loaded.. should be ok..
Re: Go ahead and laugh, I'm lazy, Why not? [Re: 67polara] #1379970
02/01/13 11:54 PM
02/01/13 11:54 PM
The Engine Oil Drain Valve has been tested and granted "Genuine Parts" status by 6 major motor vehicle manufacturers in Japan, including Toyota, Nissan, Mazda, Mitsubishi, Subaru and Isuzu. These approvals were not granted easily and gaining them was a testimony to the quality and durability of Engine Oil Drain Valve.
Re: Go ahead and laugh, I'm lazy, Why not? [Re: BDW] #1379971
02/02/13 12:00 AM
02/02/13 12:00 AM
Australia
67polara Offline
67polara  Offline
Australia
best of luck,
If it aint broke don't fix it
Re: Go ahead and laugh, I'm lazy, Why not? [Re: BDW] #1379972
02/02/13 12:00 AM
02/02/13 12:00 AM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
It appears that the clocking of the valve is determined by when you run out of threads while tightening it, correct?
Where is the one on your Mustang clocked, and is the tension on the spring enough so it doesn't matter?
Down to just a blue car now.
Re: Go ahead and laugh, I'm lazy, Why not? [Re: 68HemiB] #1379973
02/02/13 12:06 AM
02/02/13 12:06 AM
Correct,
The lock has an indent, the spring and the rotational tension is very high.
Takes a lot of force to rotate the lever open.
Re: Go ahead and laugh, I'm lazy, Why not? [Re: BDW] #1379974
02/02/13 12:36 AM
02/02/13 12:36 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Would you put it on a race car........if not then why on a street car?
Drain bolt = one (1) moving part. Proven pretty darn reliable, about a $1 or two at the most. A good running engine with oil in it, about $$$$$$.
How often do you change the oil to have to use a quick drain system?
What's next a "dry-break" system for the gas tank filler because a quarter turn cap takes too much time to open and close?
Re: Go ahead and laugh, I'm lazy, Why not? [Re: BDW] #1379975
02/02/13 12:38 AM
02/02/13 12:38 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Correct,
Sounds like more effort than turning a wrench, so what's the gain again?
Re: Go ahead and laugh, I'm lazy, Why not? [Re: BDW] #1379976
02/02/13 12:40 AM
02/02/13 12:40 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Of course, if you have any enemies, it could also leave you stranded due to the ease with which the oil could be drained. I'm just saying...
Re: Go ahead and laugh, I'm lazy, Why not? [Re: BDW] #1379977
02/02/13 12:42 AM
02/02/13 12:42 AM
Kirkland, Washington
Pacnorthcuda Offline
Another dissadvantage I see is that the drain low-point is raised by the thickness of the thickness of the ID vs the OD of the fitting. From now on you are unable to fully drain the pan by about 1/8" ??? I think of the crap that could collect over time.
Re: Go ahead and laugh, I'm lazy, Why not? [Re: Pacnorthcuda] #1379978
02/02/13 12:51 AM
02/02/13 12:51 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Better question; Would you put it on your airplane?
Re: Go ahead and laugh, I'm lazy, Why not? [Re: A12] #1379979
02/02/13 12:56 AM
02/02/13 12:56 AM
San Jose, Ca.
dhkennedy Offline
dhkennedy  Offline
San Jose, Ca.
Saw on YT that a Ford has that, no cap just shove the filler in the tube.
Re: Go ahead and laugh, I'm lazy, Why not? [Re: dhkennedy] #1379980
02/02/13 01:13 AM
02/02/13 01:13 AM
vashon island washington
hunterstroble Offline
Our international line strucks have those, bounce all over and rattle around (diesel), not one has leaked.
1969 Dodge dart 500 stroker 1973 Dodge Challenger 440
Re: Go ahead and laugh, I'm lazy, Why not? [Re: Pacnorthcuda] #1379981
02/02/13 01:14 AM
02/02/13 01:14 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I do see one advantage: I like to change my oil with the engine warm and as much of the sediment in suspension. The bolt always ends up in the hot oil when I take it off. This way, no bolt to lose.
Re: Go ahead and laugh, I'm lazy, Why not? [Re: denfireguy] #1379982
02/02/13 01:19 AM
02/02/13 01:19 AM
Castlegar, BC, Canada
That AMC Guy Offline
I think the next logical step would be to make a drain valve that takes a hex or torx style bit to turn.
Granted, I've never really had people crawling under my cars trying to figure out what oil drain plug I had, but something with a little security makes sense.
I'll admit, I do get tired of having 5 cars all with different size drain plugs and not having the mental facilities to remember which car has what.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Page 1 of 3 1 2 3
