46re no lockup ? #1379679
02/01/13 11:19 AM
02/01/13 11:19 AM
Fortworth TX
mod5v Offline OP
mod5v  Offline OP
Fortworth TX
Ok so I picked up a rust free 96 ram1500 standard cab short box 318/46re for 600$. was told trany slips when warmed up. So I droped the pan it was real clean inside. I installed the "sure cure" kit in the valve body and adjusted the bands. I also replaced the the govenor presure/overdrive solinoids. I installed a cooler and removed the checkvalve and filled it with ATF+4. I have drove it about 75 miles now and really don't think the trany is "slipping" but I don't think the torque coverter is locking up. It has 3.55 gears and 265-70-16 tires and runs 2000rpm at 60 which seams kind of high was thinking it should be more like 1600. How can I check to make sure its a bad converter and not something else. I have a code reader but not a scanner.
Re: 46re no lockup ? [Re: mod5v] #1379680
02/01/13 04:11 PM
02/01/13 04:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Lock out the OD and accelerate through the gears, after the 2-3 upshift you should be able to feel the converter lockup with an accompanying drop in rpm on the tach.
Re: 46re no lockup ? [Re: John_Kunkel] #1379681
02/01/13 06:05 PM
02/01/13 06:05 PM
dogdays Offline
dogdays  Offline
I should know this, but what's the OD ratio? I calculate 2340 rpm at 60 in Third with converter locked.
R.
Re: 46re no lockup ? [Re: dogdays] #1379682
02/01/13 06:44 PM
02/01/13 06:44 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I think it's .69:1.
Re: 46re no lockup ? [Re: John_Kunkel] #1379683
02/01/13 09:03 PM
02/01/13 09:03 PM
Fortworth TX
mod5v Offline OP
mod5v  Offline OP
Fortworth TX
Yea I tried that and still no lockup. It dose go into overdrive just fine.
Re: 46re no lockup ? [Re: mod5v] #1379684
02/02/13 04:00 PM
02/02/13 04:00 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Dont be suprised if it needs a torque converter. The lock-up clutch is not very stout in them. I've replaced many of them. If you put a converter in it, do yourself a favor and pull the pump and inspect it for wear where the input shaft goes through the stator. A new converter bushing and seal is also a good idea. I would also replace the sealing rings on the input shaft with the updated interlocking style rings for better sealing. You can also drill the relief hole in the boost valve cover to about .070 for better apply pressure to the lock -up clutch. Its a small metal cover on the top side of the valve body held on with 3 T-25 screws with a tiny hole in it.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 46re no lockup ? [Re: mod5v] #1379685
02/02/13 05:01 PM
02/02/13 05:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You could try replacing the lockup solenoid, it's on top of the valve body.
Re: 46re no lockup ? [Re: John_Kunkel] #1379686
02/03/13 12:18 PM
02/03/13 12:18 PM
Fortworth TX
mod5v Offline OP
mod5v  Offline OP
Fortworth TX
I drilled the hole as it is part of the "sure cure" kit. I am looking for a afordable scanner that will display the different real time outputs so I can see if the computer is telling the converter to lockup. If I can't find one I guess I'll take it to a trany shop and have them scan it.
Re: 46re no lockup ? [Re: mod5v] #1379687
02/03/13 12:44 PM
02/03/13 12:44 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
I just went through this on mine. My transmission ended up needing a rebuild (not cheap, by the way), but I learned a couple things along the way. Since your fluid is clean, I suspect it's overheating and kicking into "limp mode" which very much feels like it's slipping. Seemingly, a very common cause for the transmission overheating is the check valve in the transmission line. The first thing I'd do is remove it, and replace it with HIGH PRESSURE 3/8" hose. The attached shows you where it is. I didn't get so elaborate when I removed mine; just cut the pre-made line where it comes out of the radiator and put the new hose in with some good clamps. If you research the subject you'll realize that just how common the problem is...
http://dodgeforum.com/forum/2nd-gen-ram/182742-trans-check-valve-delete.html
Re: 46re no lockup ? [Re: Fat_Mike] #1379688
02/03/13 01:17 PM
02/03/13 01:17 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
the check valve is a spring and a rubber ball all you have to do is run a drill bit in the end of the hose and you can get all of it out without replacing anything
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 46re no lockup ? [Re: dusturbd340W5] #1379689
02/03/13 09:07 PM
02/03/13 09:07 PM
Fortworth TX
mod5v Offline OP
mod5v  Offline OP
Fortworth TX
Well I did remove the check valve and installed a plate cooler and bypassed the cooler in the radiator. I'm going to have to scan it as I have also replaced the overdrive/lockup solinoids and the pressure sensor.
