Setting cam end play #1379655
02/01/13 03:30 AM
02/01/13 03:30 AM
Middle of the US
V
Verga Offline OP
Verga  Offline OP
V
Middle of the US
Is it acceptable to set cam end play with timing chain off, but cam gear on cam? I ask because my cam has none to very very little movement with chain on.
Also, I thought about welding something on the outside of timing cover to be sandwiched by the water pump housing, to stiffen the cover? Sound ok?
"Im supercharged, might explode in your face"
Re: Setting cam end play [Re: Verga] #1379656
02/01/13 03:49 AM
02/01/13 03:49 AM
Check it like it will be used
Re: Setting cam end play [Re: Cab_Burge] #1379657
02/01/13 11:14 AM
02/01/13 11:14 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Cam buttons are available through Mancini as well as others. Don't know if that's what you are looking for or not.
This is the land of the free because of the brave
Re: Setting cam end play [Re: Verga] #1379658
02/01/13 11:31 AM
02/01/13 11:31 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Setting it with no chain on is fine.
Are you running a roller cam? A roller cam needs something to limit its movement. A solid or hydraulic cam does not.
Finding an off the shelf button that will fit and give you the right clearance is virtually impossible. Avoid the nice, expensive roller bearing style because these can't easily be clearanced to fit. Avoid aluminum buttons because they will gall. The nylon ones are the best choice since they can easily be ground or filed to fit and the finished surface doesn't matter. If a button is too short (too much end play), cut a piece of the correct thickness feeler gauge and put it behind the button.
