Setting cam end play
#1379655
02/01/13 03:30 AM
02/01/13 03:30 AM
Posts: 302 Middle of the US
Verga
Middle of the US
Is it acceptable to set cam end play with timing chain off, but cam gear on cam? I ask because my cam has none to very very little movement with chain on.
Also, I thought about welding something on the outside of timing cover to be sandwiched by the water pump housing, to stiffen the cover? Sound ok?
"Im supercharged, might explode in your face"
Re: Setting cam end play
[Re: Cab_Burge]
#1379657
02/01/13 11:14 AM
02/01/13 11:14 AM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
Cam buttons are available through Mancini as well as others. Don't know if that's what you are looking for or not.
This is the land of the free
because of the brave
