K & N air filters #1379064
01/31/13 01:43 AM
01/31/13 01:43 AM
Tucson, AZ
Ramrod39 Offline OP
My New Title
Ramrod39  Offline OP
My New Title
Tucson, AZ
Thinking about trying one on my 493. I like the idea of pulling air through the lid. They look kind of cool, too.
Who has tried them? Good? bad?
Re: K & N air filters [Re: Ramrod39] #1379065
01/31/13 01:45 AM
01/31/13 01:45 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Do some research on the internet then decide for yourself. I've read a few articles of engines that had used oil analysis done on them getting a lot more crap in the oil that gets past those k&n and similar type filters. I stick with the good old paper jobbers but to each his own.
Re: K & N air filters [Re: Ramrod39] #1379066
01/31/13 01:50 AM
01/31/13 01:50 AM
Kirkland, Washington
Pacnorthcuda Offline
I've been using them for 30 plus year. No worries here. BUT I don't live in a very dusty
climate.
I,ve never worn out an engine due to cylinder/bearing wear.
Re: K & N air filters [Re: Ramrod39] #1379067
01/31/13 01:51 AM
01/31/13 01:51 AM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I've never used the lid you're talking about but the filters in my opinion are excellent, easy to clean and a bargain.
Re: K & N air filters [Re: Ramrod39] #1379068
01/31/13 02:11 AM
01/31/13 02:11 AM
San Jose, Ca.
dhkennedy Offline
dhkennedy  Offline
San Jose, Ca.
I have run K&N on all of of mine for 21 years. Here is what I have found out on each car. Daily driver72 Dart 318 with 8" Volicity Stack in Mini Mopar hood scoop: Great water repelant from oil.Daily driver and NMRO Stock class 79 RC with 440-6: Kept mud and water out even though it was open housing. 07 Nitro has 130,000 and cleaned once. 07 HD Wide Glide: Freaking mess, oil everywhere in TB, even after letting it sit for "excess" to drain.01 Kawi Nomad EFI filter Failed: tear engine down to remove pieces from cylinders.75 D 100 440 with STP 305A size filter: Oil did not stay in filterand had to reapply every 2000 miles, screwed with FAST EX EFI, pulled and tossed. There are other brands that may be better without the oil mess. I prefer them due to the amout of water mine see.
Re: K & N air filters [Re: dhkennedy] #1379069
01/31/13 09:37 AM
01/31/13 09:37 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i have the filter and top on 2 of my cars, i cant say if it made a difference as they never had anything else on them. i can say i put a K&N replacement filter in my 03 dakota w/3.9 and gained 1 MPG. i confirmed it many time before and after putting the filter in.
Re: K & N air filters [Re: 65rbdodge] #1379070
01/31/13 11:10 AM
01/31/13 11:10 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I've never had anything else on mine to compare. Never even did a back to back without the filter
But it's good for low 10's
Re: K & N air filters [Re: Ramrod39] #1379071
01/31/13 11:15 AM
01/31/13 11:15 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
As mentioned the lid might be a good idea if you are not getting enough air thru the element, however its a proven fact that the oil bath filters do not filter or perform better than the CORRECT size paper. I have run K&N's before but I find them a PAIN to clean and re-oil. Old paper in the trash new paper in...done.
Coming soon!!!!
Re: K & N air filters [Re: Mr.Yuck] #1379072
01/31/13 12:07 PM
01/31/13 12:07 PM
What's the best brand(s) of paper element to ask for?
Re: K & N air filters [Re: RapidRobert] #1379073
01/31/13 12:17 PM
01/31/13 12:17 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
??? I typically use the NAPA brand I think they are made by WIX. I will add I do not use a lid at the ttrack, just the base plate and filter.
Re: K & N air filters [Re: Mr.Yuck] #1379074
01/31/13 02:27 PM
01/31/13 02:27 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My kid runs both the filter and lid on his 62 300 413.It picked up maybe a 1/10th.I run Summits 6 inch on my built 440.Its been on for probally 6 years.Buy Summits its the same thing just a lot cheaper.Rocky
Chrysler Firepower
