intake choice #1378576
01/30/13 12:56 PM
01/30/13 12:56 PM
indy
70moparmike Offline OP
indy
i am building a 500 stroker,4sd, 3:54, 440 in a 69 gtx. i see the performer rpm is not going to fit under my hood, i have a air grabber, but would delete it if it would fit? what manifold would you suggest to get the most hp? stealth heads, trying to keep stock looking, and around 550-600 hp range. may not be attainable with intake? thanks for input.
Re: intake choice [Re: 70moparmike] #1378577
01/30/13 01:26 PM
01/30/13 01:26 PM
indy
indy
Re: intake choice [Re: 70moparmike] #1378578
01/30/13 01:34 PM
01/30/13 01:34 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
The holley street dominator should be able to handle it. It's pretty low.
Re: intake choice [Re: 70moparmike] #1378579
01/30/13 01:54 PM
01/30/13 01:54 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
if it is an rb block, i would use the indy 440-2d dualplane.it also sits very low.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: intake choice [Re: Old School] #1378580
01/30/13 02:02 PM
01/30/13 02:02 PM
indy
indy
thanks i'll look that up.
Re: intake choice [Re: 70moparmike] #1378581
01/30/13 02:07 PM
01/30/13 02:07 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
while that is a great intake...I believe the Indy Dual plan is even taller than the RPM.
Re: intake choice [Re: Quicksilver440] #1378582
01/30/13 04:29 PM
01/30/13 04:29 PM
indy
indy
you are correct, it is.
Re: intake choice [Re: 70moparmike] #1378583
01/30/13 04:49 PM
01/30/13 04:49 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I don't have both side by side but I've used both manifolds and I believe the Indy 2-D is fractionally lower than the Edelbrock Performer RPM on a 440. Much bigger internally but lower at the carb flange.
Someone I'm sure has the dimensions but I'm 99% sure I'm correct, I can run a 5/8" spacer on the Indy and still close the hood of a 70 Charger, can't with an RPM
WIZE
In Car:
Re: intake choice [Re: Streetwize] #1378584
01/30/13 05:27 PM
01/30/13 05:27 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Here is a pic of the Indy dual plane intake I use on my 493. Ron
Re: intake choice [Re: 383man] #1378585
01/30/13 05:32 PM
01/30/13 05:32 PM
indy
indy
do you have a scoupe on yours?
Re: intake choice [Re: Streetwize] #1378586
01/30/13 07:28 PM
01/30/13 07:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Bobby , what are you using for an air cleaner ? That's interesting as I would have thought the Indy would be taller
Re: intake choice [Re: 70moparmike] #1378587
01/30/13 09:46 PM
01/30/13 09:46 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Actually, they are the same height, plus/minus an 1/8. I run the Indy with a 1/2" spacer
Re: intake choice [Re: 70moparmike] #1378588
01/30/13 10:38 PM
01/30/13 10:38 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
I have a 493 with Eddy heads and a Holley SD in my 69 GTX with the air grabber. No clearance problem. You will even have room for a 1/2 to 1 inch wood spacer to keep your fuel from boiling.
The SD performs VERY well. 3.73 gear 3900lbs runs 10.80 on pump gas full exhaust on Hoosier drag radials.
Re: intake choice [Re: mercman1] #1378589
01/31/13 11:18 AM
01/31/13 11:18 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
JohnRR,
Just a 14" drop base, need to go to a 16" though.
I think the 4402d ser's the carb just a hair lower than the RPM.
I will say for the original poster's question a ported Holley SD would work great, with work you can get the ports to flow ~320 cfm (~270 ish stock) the Sd is lower than the other 2
WIZE
In Car:
Re: intake choice [Re: Streetwize] #1378590
01/31/13 11:24 AM
01/31/13 11:24 AM
indy
indy
can you get the air grabber to work with this manifold?
Re: intake choice [Re: Streetwize] #1378591
01/31/13 11:26 AM
01/31/13 11:26 AM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
2X4 Edelbrock will fit. Mine was fine till I added the carb spacers. A drop base air cleaner from a Hemi will bolt right on but there's lots of alternatives. Just be careful of the center posts. Lots of hoods dented because they were to tall. I decided to go fiberglass, now I have lots of room.
Re: intake choice [Re: 70moparmike] #1378592
01/31/13 11:43 AM
01/31/13 11:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You can get the air grabber to work with almost any manifold , how are your fab skills ?
Re: intake choice [Re: JohnRR] #1378593
01/31/13 12:09 PM
01/31/13 12:09 PM
indy
indy
it will fit, just 1/2 clearance if that, between top of airhorn and bottom of lid?? not enough for air i would think?
