Re: intake choice
[Re: 70moparmike]
#1378579
01/30/13 01:54 PM
01/30/13 01:54 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
if it is an rb block, i would use the indy 440-2d dualplane.it also sits very low.
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: intake choice
[Re: Streetwize]
#1378586
01/30/13 07:28 PM
01/30/13 07:28 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
I don't have both side by side but I've used both manifolds and I believe the Indy 2-D is fractionally lower than the Edelbrock Performer RPM on a 440. Much bigger internally but lower at the carb flange.
Someone I'm sure has the dimensions but I'm 99% sure I'm correct, I can run a 5/8" spacer on the Indy and still close the hood of a 70 Charger, can't with an RPM
Bobby , what are you using for an air cleaner ? That's interesting as I would have thought the Indy would be taller
Re: intake choice
[Re: 70moparmike]
#1378592
01/31/13 11:43 AM
01/31/13 11:43 AM
JohnRR
U.S.S.A.
can you get the air grabber to work with this manifold?
You can get the air grabber to work with almost any manifold , how are your fab skills ?
