71-74 B Body vs 71-74 E Body Parts interchange #1378409
01/30/13 02:04 AM
01/30/13 02:04 AM
Lost in the 70's
440gtx6 Offline OP
440gtx6  Offline OP
Lost in the 70's
Could someone school me on the inter-change of body panels on these two platforms? A local yard has some 73-74 Satellites with decent body panels still available but no E body parts cars. For my 71 Cuda project I need floor panels, firewall, cowl side inner and outer hinge panels, front frame rails, and inner roof structure pieces.
I recall reading somewhere that possibly the front rails and front inner fenders were the same but I have no proof of that. I'm sure someone on here knows specifically what if anything interchanges. Or maybe someone knows a link to an interchange listing.
Thanks!
69 EF8 GTX 440 auto
72 EB5 RR/GTX 440 auto
70 EW1 GTX 440-6 4 spd
70 EF8 Satellite 318 auto (452 coming soon)
70 FK5 Satellite 318 auto
71 FC7 Cuda 340 4 spd
Re: 71-74 B Body vs 71-74 E Body Parts interchange [Re: 440gtx6] #1378410
01/30/13 02:19 AM
01/30/13 02:19 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I know the frame rails and inner fenders are the same, 70-74 e to 71-72 b. I have a complete 71 b body front from the torsion bar cross member to the radiator support and it sure looks the same as a 71 e-body, other than cowl top and windshield frame. The front floor section will swap. I do not know about later mid 72 and up b-bodies, but would bet they are not the same, after the isolated k-frame.
Re: 71-74 B Body vs 71-74 E Body Parts interchange [Re: 4406bbl] #1378411
01/30/13 03:13 AM
01/30/13 03:13 AM
Lost in the 70's
440gtx6 Offline OP
440gtx6  Offline OP
Lost in the 70's
So since these are 73-74 doesn't sound like they would yield any usable pieces for my project. Guess I will keep looking.
Thanks!
69 EF8 GTX 440 auto
Re: 71-74 B Body vs 71-74 E Body Parts interchange [Re: 440gtx6] #1378412
01/30/13 03:22 AM
01/30/13 03:22 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Very little from the 73/4B will fit your 71E. 71/2B will have alot of front end interchange.
Cowl, non-a/c firewall, hinge jams are different.
Ft floor pan, a/c firewall, t-bar cross member, front frame rails, inner wells, and radiator support will interchange.
Also K-frame, suspension and a/c heater box are the same.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 71-74 B Body vs 71-74 E Body Parts interchange [Re: 440gtx6] #1378413
01/31/13 12:34 AM
01/31/13 12:34 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Pretty much everyone is on track. Forget about the 73-74, a completely different animal. 71-72 Rad suport yes, front floors are very simular and would work, not all the way back (although the tunnel would need a little work), yes to the frame rails. The cowl and fire wall different, hinges different, anything behind that; forget about it, and of course no to the hood. The inner fenders are very close, although some of the dimpling and or holes are not all in the same places. Glass, regs and tracks all different. So all in all only a few items will work.
Re: 71-74 B Body vs 71-74 E Body Parts interchange [Re: DANA60] #1378414
01/31/13 02:14 AM
01/31/13 02:14 AM
Lost in the 70's
440gtx6 Offline OP
440gtx6  Offline OP
Lost in the 70's
That's why I come here first before I buy.
Thanks!
69 EF8 GTX 440 auto
Re: 71-74 B Body vs 71-74 E Body Parts interchange [Re: 440gtx6] #1378415
01/31/13 05:34 AM
01/31/13 05:34 AM
moparmarks Offline
moparmarks  Offline
Front floor pan and inner fenders are so close that they have the same part # between B and E.
A/C firewalls are the same but non-A/C walls are different.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 71-74 B Body vs 71-74 E Body Parts interchange [Re: 440gtx6] #1378416
04/29/14 12:23 AM
04/29/14 12:23 AM
Staten Island, NY
P
Philly Offline
Philly  Offline
P
Staten Island, NY
What about the possibility of a 71 E body A pillar fitting on a 71 B body car? Is there a difference?
