What cams are you using in your 440/505 engines?
#1378369
01/29/13 10:49 PM
01/29/13 10:49 PM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
just wondering about what cams people are using in their 505 stroker engines. Just looking for an idea. I know my application makes a big difference, but just looking to see what people use.
RS23L7 4-Speed
Re: What cams are you using in your 440/505 engines?
[Re: 383man]
#1378372
01/30/13 12:11 AM
01/30/13 12:11 AM
Posts: 2,177 ill
dennismopar73
ill
There just 2 cams that we have run the most use ,, is a Racer Brown STX 21,, and STX 22 Both use a 105 c/l STX-21 304 266 .560(1.5 rockers) .590(1.6 rockers) STX-22 310 276 .590 .629 We have used a 112 c/l on a stx 22, but no hp gain over the 105 c/l cam we have them in use with eddie rpm and sets of Victors Jr with a max CNC port job, We have had ets in the 9,50 zone with a 474 with out of the box RPM heads and the STX 21 3200 car. As for my car it weighs in at 2900 with a driver has a 437 (383 w a 440 crank) eddie RPMs out of the box, STX 21 With no tune up to speak have run 10.48 with a 1.42 60ft I still have a chassie to dial in,and a motor to tune on , I am sure that 10-0s is not out of the question for a low hp , low buck motor!!
[Re: Mopar_Mike]
#1378375
01/30/13 11:59 AM
01/30/13 11:59 AM
Posts: 12,158 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
499", ported Eddies, 10.75cr, street car w/727 & 3.91s
Scott Brown spec'd .609/.606 251*/264* 112* flat solid
Master, again and still
[Re: Mopar_Mike]
#1378376
01/30/13 01:56 PM
01/30/13 01:56 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Friend of mine just put this in his in his 496 with CNC'd eddy's and ported victor and 1050 dominator street car and he loves it. uses 1.6 hughes rockesr for .700 lift uses Iski gold springs. http://www.summitracing.com/parts/cca-23-707-9/overview/make/chryslerMechanical roller tappet Basic Operating RPM Range:4,400-7,000 Intake Duration at 050 inch Lift:275 Exhaust Duration at 050 inch Lift:285 Duration at 050 inch Lift:275 int./285 exh. Advertised Intake Duration:308 Advertised Exhaust Duration:315 Advertised Duration:308 int./315 exh. Intake Valve Lift with Factory Rocker Arm Ratio:0.657 in. Exhaust Valve Lift with Factory Rocker Arm Ratio:0.659 in. Valve Lift with Factory Rocker Arm Ratio:0.657 int./0.659 exh. Lobe Separation (degrees):108 Camshaft Gear Attachment:3-bolt replaced a 270/274 @ .050 110 LSA cam 4100 lb car with 4400 stall and 4.10 gears says noticeable hp improvements but no track time as yet! on my old 542 I used a scott brown 274/282 112 LSA .715/.702 lift with 1.6 worked good will use it in my 542 aluminum block when i get the internals. could use a we bit more I think. Old stock block went 10.11 @ 132.32 in a real stiff cross wind @ 3700 lb.
[Re: Mopar_Mike]
#1378379
01/30/13 03:53 PM
01/30/13 03:53 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Agreed.. Here is my engine:
440/505 Eagle kit 21022 10.725 deck height 4.35 bore 4.25 stroke 7.1 H-Beam rod -8.0 cc top piston 1.475 pin height 11.48.1 Compression
Indy EZ-1 Heads and Intake, QF 950
67 Coronet 3800 with me in it. 727 ( have not picked converter yet) Strange 60 with 4.10 gears and 275/60 M/T tires.
Mostly a track car.
Thanks!
If your up for buying and using a solid roller cam and lifters I have a Comp Cams custom grind solid roller that works real well It is 260 @.050 with .420 lobe lift on the intake lobes and 266@.050 with .409 exhaust lobe lift on the exhaust lobes. PM if you want the lobe numbers, they where BB Chevy lobes originally I used a set of Harland Sharp 1.65 ratio rockers originally on my Eddy RPM heads and now use a set of T&D 1.65 ratio on my Indy SR, the motor is a 518 C.I. pump gas motor that pulls like gang buster to 7800 RPM if I let it I try to shift it at or close to 7000 RPM My car will slow down a tiny bit in the 1/8 mile if I short shift it between 5800 and 6500 RPM in 1st and 2nd gear Big motors needs big air to make the most of the combination, your little tires will be the biggest challenge to make work, in my opinion You might like the same size in a bias slick or bias race street tire like the M/T ET Streets instead of the M/T ET Street Radials
[Re: Mopar_Mike]
#1378384
01/30/13 08:32 PM
01/30/13 08:32 PM
Posts: 1,505 TN
SCATPACK 1
TN
That cam has 286 duration @ 50. It will kill some of your bottom end, Sound awesome and run really strong thru 7800 to 8000 grand. I think your set up would respond better with a 266 - 274 @ 50 cam. What do your SR heads flow above 600 lift? My cousin has a similar 67 car to yours except he has a 4.56 gear and runs 29.5 X 10.50 drag slicks. He just replaced a bigger cam with a Bullet Roller cam I had that has 266 @ 50 w/ 110 lobe seperation installed at 108 and it has 670 lift. His old cam was a 286 @ 50 cam. His car is quicker and faster with the smaller cam. He has an old set of Zeeker heads that flow really well in the mid range up to 700 lift. He has a 5000 stall converter (I think).
Old Geezer Racing
[Re: Mopar_Mike]
#1378385
01/30/13 08:34 PM
01/30/13 08:34 PM
Posts: 75,047 U.S.S.A.
JohnRR
U.S.S.A.
I run crower 650 lift solid lifter , great cam but you better have a stick or a real high stall as it doesn't smooth out till 5,000 RPM"S
These are the stock EZ-1 head, I think they are rated to .600 lift? does anyone know for sure? I'd like to run over a .600, like the one above without changing spings etc.
If the springs are only rated to .600 lift then running something bigger isn't going to be a good idea .
Stop being cheap Mike , spend it because you can't take it with you ...
[Re: JohnRR]
#1378386
01/30/13 08:47 PM
01/30/13 08:47 PM
Posts: 1,505 TN
SCATPACK 1
TN
Sorry Mike, I thought you were running the SR heads. I would not run the springs that come with the EZ heads on anything at or over 600 lift. You are going to float the valves and break stuff. ASK me how I know. My son broke engine parts twice, before I got smart and replaced the springs. Yep I am a slow learner. LOL
Old Geezer Racing
