cal-trac question.... #1377628
01/28/13 05:36 PM
01/28/13 05:36 PM
michigan woods
imfixinmopars426 Offline OP
michigan woods
i bought a cal-trac mono spring,and bar set up...(for a b+e) a few swaps ago.got it pretty cheap,and was going to use it on my charger,but never did.so i am now working on my dart,and want this set-up under it...so what is different?..can i buy the shorter front spring segment?...and also can i buy the tube that is shorter for the a-body? i was just wondering if anyone knows about going from a b+e setup,to a a-body setup,and maybe an idea of the cost for the spring,and tube?....sure would be nice if i can. i already have a new d-60 narrowed,w/disc's from mosier,,,thinking the cal-trac would be perfect addition...so anyone?? thanks,in advance..mike
Re: cal-trac question.... [Re: imfixinmopars426] #1377629
01/28/13 06:27 PM
01/28/13 06:27 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Call Calvert. I'm sure they sell replacement parts. They'll also be able to tell you about the spring swap. The spring rates between A & B body springs may be an issue. Bottom line: Call Calvert!
Re: cal-trac question.... [Re: StealthWedge67] #1377630
01/28/13 07:18 PM
01/28/13 07:18 PM
michigan woods
michigan woods
ok...will do tues...i hope it will work..im cheap that way,lol
Re: cal-trac question.... [Re: imfixinmopars426] #1377631
01/31/13 01:07 PM
01/31/13 01:07 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
let me know what you find out, I might want to try the mono-leaf set-up. Easy way to findout is check the part #'s....if they are the same for A and B body then I'd guess they'd work, if not
Coming soon!!!!
Re: cal-trac question.... [Re: imfixinmopars426] #1377632
01/31/13 02:38 PM
01/31/13 02:38 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
imfixinmopars426
There is a diference between the A Body & E/B Body length of the Tubes. I believe it is like a 2" difference in length or something like that. I have an extra set for an A body laying around that were mis-packed in my E/B Body kit in error. Calvert set me the correct E/B replacement tubes at no charge. I see you are in Mi also. I will give them to you if you want them.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: cal-trac question.... [Re: Mr.Yuck] #1377633
01/31/13 04:36 PM
01/31/13 04:36 PM
1000+sbm Offline
1000+sbm  Offline
my cal-trac set up
Re: cal-trac question.... [Re: 6PKRTSE] #1377634
01/31/13 05:42 PM
01/31/13 05:42 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
imfixinmopars426
Correct. The force bars are ~2" shorter as that's the difference in front segment length between the body styles.
